Stud is 5-1/2" and plywood is 7/16".
So to get the open edge of the box flush with the face of the plywood, it has to be 5-15/16" from the 2x4 it was previously attached to. But I'll round it up to 6" because two layers of paper backing on the insulation will be between the studs and the plywood.
Box is 1-¾" deep. Or 1.75.
2x4's are 1.5" thick. Two of them = 3". So with two 2x4's the box is now at 4.75". Needs to be 6", so I got 1.25" to go.
So mill a 2x4 down to 1.25 inches..
So with the planer I milled the third 2x4 to 1-¼.
Put it together and pulled a tape measure on it and it's fucking dead on 6 inches from the 2x4 behind the studs.
Then I put the stud in, and set a straight edge in there and the damn thing was flush with the stud, not sticking out another half inch like it's supposed to.
Somehow the stud got wider or the 2x4 shims got thinner...
Nope... Tape measure doesn't lie and the stud is 5-1/2" deep and the box it 6"... So it should stick half an inch past the stud.... But of course, it doesn't.
And the straight edge is of course, straight.
So WTF'ing F??
So I sez fuck it & put washers between those two pieces to bring it even further out.
:dunno:
All that matters is what it looks like when it's done.
But I can't do anything else til I get more plywood and insulation from Menard's and those bastards are closed tomorrow. :mad:
Heater running now?
It's been running since Wednesday. :rolleyes:
When I passed by an hour or so ago, there was this huge cloud of steam shooting out over Manteno...
Maybe @Duck was just PO'd about sumthin'...
:stirpot2:
I was pissed off at my A-frame step ladder ladder because it's too tall and no matter what I did, it wouldn't shrink. :mad:
You should've stopped by so I could put the ladder between a tree and your ICC bumper and have you back up about a foot. o_O
That's what ya get fer Sanforizing® it.
o_O
That 12 foot ladder is a flimsy piece of shit.
You can make it walk just by leaning side to side.
Hard to explain but it only happens because it's flimsy.
I only bought it because my 8 foot ladder ain't gonna be tall enough if those LED ceiling lights ever burn out. I don't want to have to assemble the scaffold just to change a light bulb.
Previously I could just lean the extension ladder against a rafter.
The switch and the single outlet 8 feet up the wall are perfect when I hold a scrap piece of OSB up against them.
But this double outlet is still gonna need 2 more washers (per screw).
Same. Exact. Math.
The outer 2x4 was bowed outward but I made an angle bracket that pulled it tight up against the stud. Still way off... :dunno:
Construction Demo Salvage Inc, I betting.
It's had wind pressure on it for like 8 years l.
A post frame barn is a very simple structure.
You set posts in the ground, throw 2x4s horizontally across the posts, then screw steel siding to the 2x4's.
Those 2x4s are 2 feet apart vertically and they span 8 feet.
On a windy day you can sit in one and watch the wind pressure bend the walls inward.
Proof that the Chicago Bears suck?
Well that was the west wall that was bowed slightly outwards, and I'm ten miles from the Indiana line so I'd say it's more likely just the state of Illinois that sucks. More suction on the west wall than the east because there's like 20 times more Illinois on that side.
