Might have been because you slapped her ass and yelled, GIDDYUP TIFFANY!!
:eek:
LMAO...
There's a cute 20-something yr old chick with big ears at Farm and Fleet. The kind of chick that makes every guy hold in his beer belly when he walks past.. I've been checking out her cute face and butt for years but I don't think she has noteworthy boobs because if she did, I would have noticed her name tag years ago.
The other day I was in there at her register and when I finally noticed the name tag on her chest said "Tiffany" I couldn't help but laugh a little bit.
But I was quick witted, having consumed an adequate amount of coffee that day.. When she looked at me wondering what I was laughing about I suddenly remembered that it says "bastard" on the packaging for rat-tail file I was buying so I pointed it out, saving myself from having to awkwardly explain the real reason I was laughing.
BTW about that rat bastard file...
I broke my drill press. :mad:
The whole tapered arbor shaft fell out last week when I tried using the 4" hole saw on sheet metal.
It's pressed in, so I simply removed the hole saw, tapped it back in, then rammed the chuck down on a wood block.
It fell out again a minute later and I got pissed and bashed upwards on it with my brake drum hammer.
Well it mushroomed the bottom of it and now the cone shaped things that grab drill bits can't extend below the chuck for bits smaller than 3/8.
So to fix it I took my only rat-tail file and cut the handle off so I could chuck it up in the hand drill and used it to file the mushroomed metal away.
So now it works but it's still tight as f* and I'm not sure how to replace it.
I was busy last night so I simply sent my dad this picture and asked him to see if he can find a replacement chuck on the Google machine.
He sent me this link:
South Bend Lathe SB1372 5/8-Inch by JT3 Drill Chuck - Power Drill Chucks - Amazon.com
I don't know how to get the chuck off of the tapered arbor shaft.
I don't even know how to get the arbor back out cuz I bashed it in there pretty good.
On some drills if you look up into the chuck you can see an Allen screw but I didn't see one in mine so I'm thinking it's just a tapered thing and jammed in with force.
:dunno:
Maybe chuck up the 4" hole saw again and use a scrap piece of sheet metal? Certainly that would make it fall out again. :rolleyes:
But that solution would only work if I was replacing the shaft too.
I should get an arbor shaft for my grandpa's drill press instead. It's old but it's Made in USA.
:usflag:
:dunno:
my only way of thinking, about removing anything from a tapered shaft, would be to use a gear puller, with long enough jaws. then you'd have to press it back on. you might be able to press it back on, by simply making some sort of stack of either hard wood, or several bricks, then using the drill press handle, rotate that enough to extend the drill chuck shaft, into the new chuck.
it'll stop being pressed, when it reaches it's size of the shaft and cannot be pressed anymore.
if a gear puller does not work, you may have to jerry-rig a slide hammer, and work with that.
The platform on that drill press can't handle much downward force before it flexes. I'd have to swing it out of the way and stand a piece of 4x4 in there or something.
Maybe use a piece of wood to protect the new chuck and bash it on with a hammer.
if there is a way for you to use a hydraulic bottle jack, that'll be safer and less stress on the shaft.
you could, but then you also bought steel rods and made jacks with them..????
If you're taking about the little thing I slapped together for un-twisting the wall studs, it's just a piece of threaded rod inside a scrap of electrical conduit.
