he thought that( asbestos )was spanish for best ass:D:biglaugh:
At the elevator company in Chicago I worked at years ago, the eccentric ass hole who owned the building and one elevator company and used his 51% ownership of 5 others to make them pay him rent for space in the same building,... He was obsessed with old Cadillacs.
Half the building was full of them. All original but paint faded, rust, etc. He employed a full time body man to restore them.
And they were covered with dust.
One of the elevator mechanics took his finger and wrote "as best dust" in the dust on one of them.
Nobody ever wiped it off. :dunno:
That setup isn't going to hold that pipe. What's it weigh, like 1 pound. Your screwed!
It's 3 here right now and the wind gusting to 28. Heat can't keep place warm past 66.
Why is that horizontal pipe so long? Why not just straight up right away?
Building code.
Yeah it's stupid. Sorta..
OK it goes horizontal off the heater because I don't want to have a leak-prone nightmare on the roof.
Directly over the walk-in door is the most convenient and practical place for it.
But...
Heater needs 18" of clearance behind it.
I don't want to put a hole in the roof or build a complicated fireproof passage through the drop ceiling.
Exhaust run, when horizontal, has to be 5 feet minimum (max 30 feet but subtract 5 feet for every 90° elbow used).
Exhaust flue termination cannot be within 4 feet of any door or window (including the rollup garage door), or less than 4 feet below a soffit.
Bottom of heater has to be at least 8 feet from the floor.
With an extra $55 elbow, I could've gone north inside the barn, then straight out. But the 14" wide minimum area for the thimble would've coincided with a wall stud I already put up, once I reached 4' past the door. So this was really the only way to do it except turn south and go all the way to the south wall but then it would be subject to turbulent wind, cost an extra $200 plus $50 for a backflow preventer, and be in the way and subject to damage while I'm working on the east wall.
Pretty complicated rules for that flu. I turned 2 burners and the oven on a while ago to jump start my condo. 71 in here now. 2 outside. I'm sure I'll see the tell tale signs of frozen engines on the way to work. All of a sudden wet patches on the road then nothing then a car on the side of the road.
Let your car warm up until the gauge shows normal and heat blows out the vents before you leave home. That way you know water is making it to the heater core.
That's what killed my 1979 Dodge truck.
5 years of a teenager beating the piss out of it and what finally done it in was ice in the engine.
So you're in a condo,... Are any of the adjacent units vacant, particularly the one below you? Maybe that's why it's so cold.
This poorly insulated, 100 year old farmhouse is a comfortable 67 downstairs, probably 75 in this upstairs bedroom.
The radiators are hot as hell but a few minutes ago I was in the basement searching for air leaks with a cigarette and a can of Great Stuff and the boiler wasn't even running continuously.
I think it's 120,000 BTU.
I'm on the bottom floor. It's staying warm in here now. Just needed a jump start I guess. I remember in the old days engines freezing was common. You could pretty much tell when the temp gauge went up quick but no heat. At that point you just turned engine off and waited for warm engine to melt the ice. You could tell when the temp gauge fell quick. You got good at it after a while.
That's the best I could come up with that would be adjustable in all directions and install quickly while I'm standing on an icy ladder freezing my ass off.
I did all that indoors. Actually mounting the pipe and adjusting it's position took about 20 minutes.
I think it looks like shit but it's staying there until spring. Then while it's already locked in the exact position it needs to be, perfectly parallel to the wall and sloped upwards 1/4" per foot, in warmer weather it'll be easy enough to get accurate measurements and fabricate something not so weird looking that will be an exact fit.
Ya know, there's this marvel of modern technology that they came up with to help out with that li'l ol' problem.
Antifreeze.
Y'all oughta try it. :D
Us know, there's this marvel of modern technology that they came up with to help out with that li'l ol' problem.
Antifreeze.
:rolllaugh3:
Before glycol antifreeze they used alcohol.
But it would evaporate too quickly so they used thermostats that would keep it under 160°. Or sometimes no thermostat at all.
And that's why there's more sludge than oil in my tractor. :mad:
