I don't know if I should tape & mud that small patch of drywall.
I just couldn't get myself to put plywood above a heater, after all that overkill with the fireproofing below it.
I'll probably just fill the gap with white caulk.
I don't know what happens to taped and mudded drywall seams when it freezes. This isn't a house.
I've seen plenty of people who have drywalled their garages but none who have taped & mudded.
I always figured it was a "who gives a damn, it's a garage" thing but now I'm thinking the cold will shrink it & crack the seams.
It's 12 feet off the ground so I bet caulk would look good enough.
Was it a detached garage or was it part of the house and kept warm all the time?
It was part of the house. It had a center drain. You could park 3 cars in there if the middle car sort of parallel parked to make room for the 3rd. It wasn't heated but the walls and ceiling were insulated. If it was real cold and your car was full of snow and ice I could turn on a small electric heater for a few hours and it melted everything. It was setup to put a real heater in there but I never did.
Yeah I'd love to have a garage with a drain in the floor.
If I was rich I'd have a 1 car garage built, with a heated slab and a drain in the middle.
It would be insulated and the walls would be done up with something like that cheap vinyl stuff they use for bathroom floors. All interior electric would he done with the "wet location" outdoor stuff.
And I'd have a pressure washer and a lift.
That way I could wash the undercarriage of my Humvee after driving it in snow (or whatever stupidly expensive 4WD vehicle I've pissed money away on), then leave it in there to dry. :cool:
I forgot. I had the house built. The drain in the garage was cemented over when they poured the floor. I had to measure where it was. Got the occupancy permit then waiting till like the summer and opened it up. Drains in a garage are illegal.
Duh!!!
All the crap that drips off the bottom of a vehicle will get into the ground water.
You got a well @Duck? How would you like your drinking water with a shot of gasoline and motor oil??
So like, nothing happens when the same crap that melts off of your vehicle is creating a foot thick layer all over town and eventually will melt and flow into every storm drain in the city? :bonk:
No, I bet the real reason for the ban is to keep hillbillies from thinking it's a place to dispose of used oil and antifreeze.
Seasoning! :drool:
Seriously, though. Where do you think that shit goes anyway? Most guys clean the garage floor periodically, which in most cases, involves hosing it outside, where it goes (drum roll) into the ground. Wouldn't it be better to run it through a drain into the sewer where it goes to the water treatment plant? And if your car is leaking oil and gasoline, get the POS fixed or get rid of it, FFS.
I have two late 90s pickups, a '13 motorcycle and a 1949 motorcycle. None of them leak oil or gasoline. (the little spot from the chain oiler on the '49 isn't a leak and it has a pan under it anyway.) And most of the professional garages I've been to have drains.
So it does seem ridiculous to me to prohibit drains in private household garages.
Seasoning! :drool:
Seriously, though. Where do you think that **** goes anyway? Most guys clean the garage floor periodically, which in most cases, involves hosing it outside, where it goes (drum roll) into the ground. Wouldn't it be better to run it through a drain into the sewer where it goes to the water treatment plant? And if your car is leaking oil and gasoline, get the POS fixed or get rid of it, FFS.
Most street runoff goes to a holding pond these days, or a treatment facility.
Well I'm guessing that since government got so far out of control and you have to sign over your God-given natural human rights in order to earn a living in a lot of industries (like how the 4th & 5th amendments are null and void if you have a CDL) the drains in professional shops are probably subject to random, warrantless inspections by the EPA. They can probably go in any time they want and shove a probe down the drain and test the stuff it samples for petroleum, glycol, etc.
They can't do that with private residences.... yet.
Either that, or the law Skateboard mentioned is just a state law in New Hampshire.
But I do know the law, wherever it's in effect, is NOT because of salt/slush melting off of vehicles because if it was, car wash businesses couldn't exist. Any state that has a Blue Beacon in it obviously doesn't have a law like that.
I don't know if it's a state or local law, but the Blue Beacon in Monee, IL has a sign saying they're not allowed to use the acid stuff for polishing aluminum because of laws banning it from the storm drains.
Well, then what fucking difference does it make if it's street runoff or from a garage drain if it ends up in the same place? Seems to me it's just another "Can't Mind Our Own Business" law.
Well, then what ****ing difference does it make if it's street runoff or from a garage drain if it ends up in the same place? Seems to me it's just another "Can't Mind Our Own Business" law.
Depends on how the muninciple services are set up @Injun. That stuff that runs off your car is hazardous waste most places.
