I gotta go to Menard's now to get a pair of nuts.
During my crusade against galvanic metal corrosion, the only stainless steel pipe clamp I could find in 4" (
diameter you sophomoric imbeciles
) was a truck style band clamp for vehicle exhaust pipes.
The plan is whatever I rig up to hold the end of
my long, stiff pipe will attach via the inch long excess bolt threads on the band clamp.
The band clamp is stainless, the bolts and half-cylinder things are galvanized and the center part is aluminum.
So,....
I'm thinking flattened end of a stick of conduit, drilled and stuck under an extra nut on the clamp.
Those bolts are 7/16 and the biggest I have in my personal hardware store is 3/8.
I'm not too concerned about galvanic corrosion on the clamp. It's easily replaceable, especially since I'm not going to
ram it tight with an impact like you do on truck exhaust. It's the 50 dollar section of furnace flue I don't want to corrode.
Which reminds me... on
@Blood's green truck we replaced some exhaust stuff and noticed that it was rusted worst at the clamps.
That's because the clamps are stainless steel and the pipe is galvanized. It was designed to fail, imagine that.
So I guess in the future always use galvanized clamps on galvanized exhaust pipes.
