I decided to box it in steel instead of wood. Why not? Extra heat shield, extra heat sink.
Gonna surround the ugly stuff with mineral wool insulation. That stuff is rated for 2000° F. :cool:
That actually came out pretty nice inside. Did your dad do it after you got drunk?
:confused:
That old man can't even stay awake for more than 3 hours. :rolleyes:
If I was doing this for hire, I'd have been fired a LONG time ago.
Because I think I've got at least 30 hours invested in this damn furnace exhaust so far.
Just. The. Exhaust. :stare1:
And that's not counting all the trips to Menard's. I'm estimating by the number of times I've had to fill the kerosene cans. It costs about $5/hr to run that kerosene heater. :mad:
:confused:
Smart ol' man. You might want to review Tom Sawyer, Huck Finn and the painting 'o th' fence.
:D
:D:D
Should have hired a contractor... you'd probably be ahead by now.
:biglaugh:
:biglaugh:
It wouldn't be done my way though.
My way is better. Even if I don't know WTF I'm doing. :p
Because when I don't know WTF I'm doing, I either study and learn in the process, or I go way overkill and do it better than it needs to be.
This wall passage for the heater exhaust will be capable of handling a temperature 200° hotter than it needs to, and a fire wouldn't start until it reaches probably 4 times the heat it'll have in it. :cool:
My only concern at this point is what's going to happen with all the ice on the inside of the steel siding when it all melts and I've sealed it up airtight in there. :dunno:
The ice is from condensation. That's what happens when it's 70 degrees on one side of a piece of sheet metal and 25 on the other.
My dad said kerosene turns into water when it burns. :confused:
C12H24 + 18O2 -->12CO2 + 12H2O
All hydrocarbon combustion produces water, @Duck. Although the equation above is a perfect combustion, and real world combustion is rarely perfect. Hence the production of CO as well as the various NOx compounds generated when pressure is involved (it spikes the temp high enough for NOx creation.)
Does NOx have anything to do with rod knock or Fort Knox? o_O
BAB+BEB+BIEBER+BABY+BABY+BABY
:coocoo:
