It's 80 degrees in here.
I can't turn off the 125k BTU salamander heater cuz it'll instantly get cold in here because of this:
But damn, with both windows open and a fan blowing air out one of them, pulling ice cold air in through the other one, it's still 80° in here.
45 minutes ago it was 25° in here.
I embiggened the inside part of the wall thimble.
And moved the heater 9 inches south and one inch higher. I didn't like the spot the flue was aiming at. Wouldn't have left me much room to make the oversize thimble.
And finished the LP conversion.
And some other crap I can't remember cuz I'm tired.
The fumes are getting to @Duck. He's using cromulent words.
Ok homemade redneck wall thingy is ready to disassemble and install.
Installation will require Geezer on the scaffold inserting the side pieces while I put the screws in from outside in the SuperUltraMegaFreakinCold.
So I'll just mark out the 10-3/8" x 10-3/8" hole in the wall and say da **** with it fer tonight.
I didn't end up using the Skateboard idea but thinking about it did inspire me to go outside and look at what they did with the doors and windows. :bonk:
Here's the top right corner of one of the windows.
Galvanic and Corrosion Compatibility Dissimilar Metal Corrosion - Engineers Edge
I've got stainless steel pipe going through a galvanized wall thimble. :rolleyes:
Shouldn't be a problem but I guess I'll hook up a ground wire just for the hell of it. There's a junction box right next to the heater with a ground in it so grounding the sheet metal really is as simple as hooking up a 6 inch jumper wire with a ring terminal.
At least a dozen inappropriate jokes here.
:eek:
Carry on...
:D
:eek:
Carry on...
:D
Well I've got stainless steel screws in galvanized sheet metal, with galvanized nuts. The hot pipe carrying the exhaust is stainless steel and will loosely fit through the hole in the wall thimble.
Outside the pipe will turn 90° north and run about 6 feet horizontal. Near the end I'm going to support it with a couple of sticks of galvanized electrical conduit and a galvanized steel pipe clamp.
For the corrosion to occur they need to be in an electrically conducive path, and a path which the metal ions can flow from the more anodic metal to the more cathodic metal.
:confused-96:
I don't know if that means electricity actually has to flow through it or what.
The heater is grounded. Or it will be as soon as I hook up the wires in the panel.
Probably not a problem. Unless static electricity can occur. :dunno:
This is usually where @Hammer166 weighs in, and then @ironpony comes by afterwards and says the same thing in different words, after consulting his thesaurus. :toothpick:
:confused-96:
Since the brainster hasn't checked in, yes a galvanic current will flow across the dissimilar metal junction if there's enough potential difference. Its what causes galvanic corrosion. You still need an electrolyte to facilitate the corrosion - slightly acid water will do it. If you take the time to coat both surfaces with some protective goop to prevent direct metallic contact, you can prevent the corrosion from eating your mancave.
