Sarcastic remark goes here
But there's 4 buses & 4 straps coming in from the panels.I think rather than being wired as 4 sets of 15cells, it's set up as 3 sets of 20 cells.
Couple thoughts....But there's 4 buses & 4 straps coming in from the panels.![]()
The voltage across the output wires was the same as measuring from bus 1 & 4.Couple thoughts....
Are there any other connections you can see?
Do the output wires hook to the buses, or go elsewhere?
They way those diodes are orientated, all the buses should be the same polarity. Did you measure across the output wires? Was it the same 28 volts? Something isn't adding up!
Gettin' rescued would end the program... can't have that and stay employed ya know!Did anyone ever wonder how the **** he could make a phone with two coconuts and winding from the jet motor on the S S Minnow and not be able to make a simple damn sail boat?
Yeah.All this figuring.
Would have been alot less hassle to just put up a damn windmill. Lmao
Yep. I bet you're right.Here's some reading for you @Duck : http://www.digikey.com/en/articles/...mprove-solar-panel-efficiency-and-performance
I still think this is how your internal wiring is set up:
Have to buy a counter turning one as well or fight prop steer.Yep. I bet you're right.
And the purpose of the bypass diodes is to increase efficiency by not letting shaded or damaged cells bring down the whole thing.
I think it's best to just leave them alone and use them with two batteries, and get a 24 volt trolling motor.
Or another one identical to my 12 volt one, but that would be a pain in the ass. I'd have to make an additional transom that can flip both motors out of the water simultaneously, and rig up cable steering to when I turn one, the other turns with it and space them far enough apart the props don't hit their twin's motor housing in a sharp turn. And a pedal switch that can turn them both off at the same time. Screw that.
It's a raft, with almost no keel effect at all.Have to buy a counter turning one as well or fight prop steer.
