No its one of the head gaskets.
I thought they were rubber but then I took an exacto knife and trimmed off a piece that was hanging out the castings & it's the same stuff.
Now I gotta mail order new gaskets from Xiangchianxdong, China.
:mad:
That's the best picture I can get of the gaskets without pulling the head off.
Compressor works fine for now..
No load: 33 volts total. 10-11 across any two neighboring buses, 22 if I skip one.
6.2 volts across the whole panel with this fan running:
The fan draws 2 amps when connected to a battery.
Deep cycle battery that hasn't been touched in a few weeks..
Solar panel's main leads applied for about ten minutes & it's over 13 now.
Immediate voltage rise was only 0.02 volts but it's going up a hundredth of a volt about every 30 seconds or so. In the time it's taken me to crop these two pictures and upload them it's risen to 13.17
That's applying the whole 33 open circuit volts to a single 12 volt battery since I was unimpressed by the drop to 6 volts when I connected that little fan.
Maybe sometime other time I'll try seeing what it'll do to both of my batteries connected in series.
Right now my other battery is strapped to the ATV because I refuse to buy a new battery for it that'll only last one season. The cables I need to connect the two batteries are connected to the cables on the ATV to extend them out to the rear cargo rack & the red one is all wrapped up in electrical tape.
And I'm about to use the ATV to haul my scaffolding to the west side of the barn so I can fix the roof.
13.29 volts now.
I won't let it get over 14.
Panel is partially shaded now because the sun is beginning to move behind the barn.
Rise in battery voltage seems to have slowed down to a hundredth of a volt every 2 minutes.
I bet I could just hook the two batteries up parallel with several of these panels also hooked up parallel & run it down the river. That 30-some odd volts drops so much when a load is applied that I'm not really feeding double voltage to the batteries.
Maybe this winter if I ever get this workshop heatable I'll build a little raft for all 5 panels. I can put one side of each panel on hinges & make little prop rods like what holds up car hoods so I can tilt each panel up to 45° in the evening and just use ropes to hold the raft aimed at the sun. Or just beach it & move it every hour or so.
That's the key, @Duck . Those cells will never be near that 30 volts with any kind of load applied to them. With the results you have there, I think you can probably safely hook up a panel to your 12V batteries with only a disconnect switch for when they are fully charged.
:thumbsup:
Now if I can remember the name of that clear fixit stuff @Blood told me to use to fix the glass, if it can be pushed into the cracks like when they fix car windshields, it'll be able to absorb more light and probably provide more current.
I assembled this old f*ed up, bent up mismatched crappy unsafe scaffolding to fix the barn roof.
Most of the platforms don't fit, the X pieces don't fit.. Damn thing is rock solid north and south but wiggles like crazy east & west. And I have that top platform hanging from straps because the stupid crap doesn't have ladder rungs in the right spot. :mad:
How'd those pix get so encrappified as soon as I uploaded them?
The Geezer doesn't think this is a good idea:
I don't either but there's nothing else I can ****ing do to hold that platform level that doesn't require welding. :mad:
The pics at the top with the 2x4 & the C-clamp...
Railing in case I lose my balance.
Going to reconfigure that.
The idea for scaffolding is to have something to land on when I slide off the damn roof. Not a platform to stand on while working because most of the work needs done 8 feet from the edge. My skin slides on that steel. I'm going to cut up an old tractor inner tube to make knee pads for traction.
With the 2x4 at the west edge, I leaned on it & the whole damn scaffold leaned too. At that point I realized if I fell against it, the whole scaffold would tip over west.
So I put it in the middle & stood beside it & realized it would miss my center of mass & simply flip me over and I'd land on my head. :redface:
So I'm going to put it back by the west edge and feed garage door cable under the corrugations of the roof steel and tie the scaffolding to the rafters so it won't tip over.
That oughta work. :unsure:
It just occurred to me that when I'm done with that scaffolding I can make a little fort at the top.
Maybe put the other two sections on too. :)
Ok now the scaffolding is rock solid in all directions.
I fed ratchet straps under the steel and insulation and hooked one to the pallet rack & the other around one of the main structural posts.
I pulled it tight against the fascia, which has a 2x6 behind it.
It's now Geezer approved.
Pro Poxy 50 is the name of the product.
I haven't seen the panel yet but Lewis says it already started to yellow a bit.
But it's still putting out the same amount of power [29 volts].
He said the epoxy would have probably done 2 panels but he only had one prepped so he wasted about half.
His son in law is a chemist for Martin Marrietta and got the epoxy for $14 which is considerably cheaper than the price on the website.
Company account presumably.
I can probably get him to pick some up for me so let me know if you want some.
https://www.carter-waters.com/unitex-pro-poxy-50/product/0/unitex pro-poxy 50
The way it's looking I'll probably shelf the solar panels and move the boat to the north half of the barn until spring.
I keep getting sidetracked on things other than completing the workshop and it'll be cold soon.
The solar panels are small enough I can carry them in the house to paint that masonry crack filler stuff on them during winter.
The living room is still unfurnished because we never repaired the burns in the floor after the fire that was nearly two years ago.. :rolleyes:
That means it's a good little work space unless that crack filler stuff produces a lot of fumes.
I'll probably hold off on the masonry crack filler until I find out more about the stuff they use to fix cracks in car windshields.
Whatever I use it'll need to dry clear, flexible, be UV proof & be thin enough when wet that it'll gravity flow into the cracks.
The cracks deprive the cells of sunlight by changing the direction of the light. Refraction or whatever it's called.
Variables don't seem to make as much difference as you would think.
I think I told you that we covered panels with several things...
A double paned window, plexiglass, double layered [uv protected greenhouse film, a black screen from an old big screen tv, etc.
Nothing seemed to effect the output much.
It surprised me to learn that solar uses only about 7% of the light spectrum.
They don't use any UV or infrared which is most of the spectrum.
Yeah the sun produces a hell of a lot of energy.
93 million miles away, filtered by the Van Allen belts and the ozone layer and all that blah blah, it's incredible. It's like a million nuclear bombs going off every second for billions of years. And scientists don't have anything but rambling, convoluted theories about where all that energy came from.
