Yeah the sun produces a hell of a lot of energy.
93 million miles away, filtered by the Van Allen belts and the ozone layer and all that blah blah, it's incredible. It's like a million nuclear bombs going off every second for billions of years. And scientists don't have anything but rambling, convoluted theories about where all that energy came from.
Nah @Duck, it's pretty simple. E=mc^2 and such.
Please show your work.
Ok.:D
The Sun's output is about 3.8 x 10^36 Watts. Since that's power and not energy, we divide both sides of E =mc^2 by 1/sec, giving us P=mc^2 / s, and solving that for mass gives us:
P / c^2 = mass / sec
or
3.8 x 10^26 / C^2 = 4.2 x 10^9 kg/s
Now when hydrogen fuses to helium, about .7% of the mass is converted to energy, so we divide the above number by .007 to determine the total mass involved, which comes out to:
604 x 10^9 kg/s or 313,000 years per earth mass.
The mass of the sun is known from orbital mechanics as 1.99 x 10^30 kg, dividing that by the consumption rate above gives us the time the hydrogen fuel will last if all of it could be fused. But it can't, only about 10% is usable fusion fuel.
So if we want to figure out how long the sun will last....
1.99 x 10^30 kg * 10% / 604 x 10^9 kg/s = 3.29 x 10^17 seconds = 10.4 billion years
Radio-carbon dating is supposed to indicate the sun is 5 billion years old, so we've got another 5 billion or so to finalize plans for your solar array before the Sun's output changes significantly.
See? Easy peasy!:headscratch2:
Variables don't seem to make as much difference as you would think.
I think I told you that we covered panels with several things...
A double paned window, plexiglass, double layered [uv protected greenhouse film, a black screen from an old big screen tv, etc.
Nothing seemed to effect the output much.
It surprised me to learn that solar uses only about 7% of the light spectrum.
They don't use any UV or infrared which is most of the spectrum.
Solar cells are semiconductors taking advantage of the photoelectric effect - Einstein got his Nobel Prize for figgurin' this stuff out. Electrons are bounced to a higher energy state by a absorbing a photon of light of the right frequency (color) which also corresponds to the right energy level. By a little masterful alchemy - of adding the right dose of impurity elements to the basic silicon (or other semiconductor material) that they're made out of, you get a batch of valence electrons that can be jolted right out of the atom they're attached to, and become conductance electrons.
The thing is, that quanta of energy the atom absorbs to knock the electron loose has ta be just right. Not too red, not too violet. Kinda like Goldielocks Porridge. Just right.
Pretty good redneckery ta figger that stuff out, huh?
And just because my brain is now engaged, I'd thought I'd see what the max wattage your panel could receive from the sun calculates to.
If we use 93 million miles as the radius of our orbit, a sphere that enclosed our orbit would have a surface area of 3.03 x 10^24 sq. ft. Figuring your panel at 2' x 4', or 8 sq. ft., means that one panel would get
3.8 x 10^24 Watts x (8 sq. ft. / 3.03 x 10^24 sq. ft.) = 1000W maximum if it was receiving 100% of the suns energy over its surface area.
20% loss over 93 million miles ain't too shabby! :clap:
Ok.:D
or
See? Easy peasy!
Yep.
Rambling & convoluted. ;)
I am the biggest nerd ever to walk the face of the Earth.
Therefore I find rambling & convoluted explanations of algebra and nuclear physics to be "elegant".
Fixed. :D
Y'all can take your atoms & photons & electrons & protoplasm and stick it where the sun don't shine...
... which would be the dark side of the moon.
So get busy making a rocket to get it there. ;)
Meanwhile I'll just sit here and listen to the Pink Floyd version. :D
Fixed. :D
Dumbazz...
:thefinger:
Without us nerds you'd still be wondering why you weren't getting a fire to start by staring at a pile of wet sticks.
Dumbazz...
:thefinger:
So the cave man who first discovered how to make fire was a nerd?
Bad analogy though.
Any redneck can get wet wood to burn if he pours enough gasoline on the pile. :D
Here's a question for you nerdly rednecks here. Serious now, need some input.
In the flood aftermath I had to pull all the insulation off the bottom of the trailer cause it got soaked in the "waters" and ruined. Fiberglass mat that went from 6 inches thick to about 1.5 or so. Full of mold as well natch. Working by myself, it's been a beach of a job. Weather sucks; pretty much long periods of heavy rain every day and having to repair/replace inside stuff that got wet and moldy too.
Anyways.....
It's just about time to replace the insulation. I've looked over the options and brought it down to 3.
1. Fiberglass mat (as original). Material costs for the cheapest, lowest R value is around $800 and it needs a plastic sheeting cover for about another $300. Labor will be a female dog and longevity is suspect as seen by the original. Least favorite for me and my old back.
2. Spray foam. This is basically MDI/TDI mixed with Polyols. Real familiar with these cause it's what I haul. Dangerous stuff. Lowes has DIY kits that sell for around $800 each and cover approx 600 board feet each. I need 1280, so looking at min 2 kits. That's at least $1600 just for material. Tried contacting contractor for this. No response except for 1. Not worth their while, would charge over $1000 just to "prep". No guarantee for application. At least 3 months before they could even look at it cause they're doing "real houses" via FEMA
3.Poly Pro insulating board. Basically a 1 inch thick close cell 4 ft x 8 ft closed cell board with one side coated in reflective foil. Materials would run about $640 (40 sheets) to cover the 1280 ft area. This is what I'm leaning to right now.
So, Duck, et al.... how would you proceed?
"Real houses," huh?
:rolleyes:
So... that puts you one step above a chicken coop?
:mad:
3) sounds easier to deal with for replacement after the next flood, relatively easy to install. 2) might be easier to get done, pain for replacement, then there's outgassing as it cures.
Anyways.....
Have you considered just insulating the skirting? If you make sure it's sealed up tight it would serve the same purpose and be less labor intentsive. It would be more susceptible to water as would basically be at ground level, but you could probably just use styrofoam sheet and use the canned foam for the gaps, and it wouldn't matter if it got wet.
How cold does it get in Louisiana? Do you even need insulation under the floor?
How about just get that $300 plastic sheeting you mentioned & put it across the bottom and be done with it?
I've heard from several people in the business that the best insulation for floors is air.. although it doesn't make sense to me and I bet anyone who spent time in a skirted RV in the ND oil fields will disagree. But you're on the gulf coast so...
If you must insulate, I'd go with (3) I'd only go with hammer's idea if the trailer is parked on a cement slab. If it's bare dirt or gravel, you won't be able to get a good seal between the skirting & the ground, and any openings created by burrowing animals would make the insulation useless until it's filled in.
Also that closed cell foam floats. I've um,.. verified this. ;)
If you insulate the skirting with foam sheets you'll have to attach it VERY securely or it'll all come loose the next time there's a flood, even if it's only a foot of water. You would have to wash & thoroughly dry the insides if the skirting so adhesive will stick to it.
