@Hammer166 This is inside the plastic boxes on the back of one of the solar panels.
I don't know if @Blood has popped the cover off of one yet.
Looks like 4 individual circuits that would be 7.5 volts each?
But what are those cylinder shaped things?
Diodes?
The black things with the silver band on the right side? Those are diodes... might be zener diodes to prevent the open circuit voltage from exceeding the rated spec.
And/or a plain ol' diode used in series with the cell array to prevent a reverse current from damaging them.
@Hammer166 This is inside the plastic bottles on the back of one of the solar panels.
Diodes?
Schottky Diodes.
per wiki:
Reverse current and discharge protection[edit]
Because of a Schottky diode's low forward voltage drop; less energy is wasted as heat, making them the most efficient choice for applications sensitive to efficiency. For instance, they are used in stand-alone ("off-grid") photovoltaic (PV) systems to prevent batteriesfrom discharging through the solar panels at night, called "blocking diodes". They are also used in grid-connected systems with multiple strings connected in parallel, in order to prevent reverse current flowing from adjacent strings through shaded strings if the "bypass diodes" have failed.
But yeah, it would only take a second with a voltmeter to verify, but that looks like 4 circuits. Clip out the middle diodes pull power off the outer conduct pairs, and you'll have 2 15+V power supplies.
<-------- The google fu is strong in this one!
Plain ol' diode.... the schottky variety just has a lower forward voltade drop to minimize how much drop you get between the solar cell and the panel terminal.
Do I need to post the fucking spec sheet showing that part number is a Schottky?
15SQ045
Outer conduct pairs? :confused-96:
Maybe you can dumb it down? I'm a truck driver fer cripes sake... :confused:
Anyway I just photoshopped it a bit to add some references.
OK I numbered the 4 bars or columns, terminals, or whatever.. And labeled the two hypothetical 15 volt circuits A & B in green.
At the bottom the red - & + label it's factory configuration.
So if I remove the center diodes I highlighted red, then column 2 will become the positive for circuit A and column 3 will become the negative for circuit B?
OK let's say that there's more hail damage affecting circuit B... If I hook the two newly created 15 volt circuits in parallel, will the healthier cell cook the more damaged one?
Actually I'll dumb down the photoshopping....
So if I do this,... Notice I blacked out the center diodes,..... it will simply convert the panel to 15 volts while maintaining the same wattage, using the existing output cables?
Meanwhile, in Manteno,
I think the way the diodes are installed, each block has two connections and not just one. I think you'll 7.5v across the left and right pins of each block. So in your drawing, the red wire needs to be moved over to the opposite side of the same block on both ends.
Ok I just took it out in the daylight & just finished photoshopping the pictures for clarity and shrinking them so I can upload them in under 20 minutes per picture with my slow internet.
First two pictures just show the amount of light I was working with because the voltage is slightly less than what @Blood said he was getting.
4 more pix coming...
It doesn't matter where on each of the 4 buses I put the meter probes.
The flat strips at the top give the same readings as any points below but it's easier to hold the probes with one hand while taking a picture with the other if the probes are in the holes where they'll stay put.
Anyhoo, buses 1 & 2 produce 9.2 volts in this amount of light, while 3 & 4 produce 8.3 volts.
With the whole panel producing roughly 27.7 volts total I can't seem to get (roughly) 13.85 volts anywhere. I don't get it..
I think rather than being wired as 4 sets of 15cells, it's set up as 3 sets of 20 cells. That would explain those readings. And remember that is open circuit voltage. Rig up some leads to connect 2 buses to a battery and see what you get for voltage then.
