No shit, Sherlock. Pretty sure that's exactly what I said.Infrared my boy. Hot objects may radiate, but cold objects absorb. Until they come into a state of equilibrium.
That doesn't change the fact that cold objects do not radiate cold.
Just means ya got a numb butt doofus!Don't know about you but when I stand next to a cold object I can feel the cold even though I'm not touching it. So, in my book, that means it's radiating cold.
just look at all of the hot air that come from politicians mouths!!! Duck could save a ton on propaneThat's stupid. How can a convention make a heater work????
Hey @Hammer166!! You gonna chew thus goombah out too???Quick explanation for this^
If you're in a room at normal temps, everything is constantly radiating in the infrared. Because everything is close in temperature, the radiation in and out is roughly balanced. When you are near a cold object, you feel the cold because your radiation out is much greater than what you receive from the much colder object. So the cold you feel radiating is actually just a much higher net radiation out from your body.
Well that would instantly raise the temperature in the workshop, right?
i'm in the process of designing my hunting and fishing cabin. and that will be off the grid to after getting a round about qoute on what it would cost to run power lines to the place.. ooppss did i forget to mention free surprizeWhen we first built the barn, the county inspector showed up giving us crap about the electric.
Kept saying it all had to be in conduit, needed locate marks, buried cable had to be inspected prior to filling in the trench, etc.
So we waited 8 years & he never came back so we said **** it.
. since this place will be off the grid 100%. i know that things like 4/0 welding cables wich handle more power vs the off grid cables wich cost more than the welding cables
but the welding cables are not rated for off grid use
If it's 100% off grid, you don't have power lines run to the property.i'm in the process of designing my hunting and fishing cabin. and that will be off the grid to after getting a round about qoute on what it would cost to run power lines to the place.. ooppss did i forget to mention free surprize. since this place will be off the grid 100%. i know that things like 4/0 welding cables wich handle more power vs the off grid cables wich cost more than the welding cables
i know that i would be dependent on wind solar and a standby genset i'm already way ahead of youIf it's 100% off grid, you don't have power lines run to the property.
If you do, it's not "off grid"...
. i seen em run lines i remember seeing 50 people out on a job that looked like it only took ten people to do
. i can go from mild to wild on an off grid setup anything from cheap harbor freight crap to a full fledged power plant setup
