@Injun is radiating severe unchumliness today.
:D
Invention... extremely simple "bottle jack". Threaded rod inside a scrap of conduit..
Also works as a spreader.
Compensating for warped lumber. :mad:
Another invention.. Plywood helper thing. Holds the bottom of the upper plywood in place while I tap it into position and get the first two screws in, while creating an ⅛" expansion gap.
It limits my vocabulary to only American English cuss words. I don't need Google Translate. ;)
To keep future warp out of your plywood you should have used clips.
No just maintain an eighth inch gap all the way around.
Clips are for unsupported edges. (no framing lumber behind the seam, - i.e. piss-poor planning) The perimeter of all the wall plywoods I'm putting up are secured to lumber with screws every foot or so. If I ever see any bubbles all I gotta do is add more screws.
Wall is 13' 5".
It's a pole barn so it's 6x6 posts with 2x4's nailed across them horizontally and the siding is screwed to the outside of the 2x4's.
At the top, on both sides of the posts are 2x12 headers that share the weight of the roof trusses.
Because a 6x6 post is the same 5-1/2" as a 2x6, I closed off the gaps between the two parallel headers by tapping 2x6's in there sideways. Those form the wall headers and I'm tee-ing the 2x6 studs into them. At the floor I'm doing the same thing except with pressure treated, masonry screws and caulk.
The studs are every two feet. So every other stud is shared by the vertical edges of two plywoods.
At the 8' mark I'm putting horizontal pieces in to screw the tops of the lower plywoods to, and the bottoms of the 5 foot upper plywoods.
At the 4' and 10'6" marks I'm putting horizontals in too, but only because of fire code.
I'm not even sure if that code is applicable to a single story outbuilding with insulated walls though. I think it's just for uninsulated (hollow) interior walls in houses.
But I'm doing it anyway because it makes the walls feel more solid.
