Out here it is $1.94 a gallon also charge of fuel recovery $4.33 and haz mat $5.69. Duck probably pay more he in a rich state.
it's 3.64 here:eek:. only reason i went with a natural gas genset is so i could plumb it right into the natural gas line since gas is cheap out here over anything else. the next genset will be a diesel i can either feed it used veg oil or i can call a heating company and have them deliver a tankful of mixed#1 and #2 wich is cheaper than the on road TAXED diesel;)
o_O
$1.06 delivered here, total cost.
Most companies have a 250 gallon minimum but don't enforce it during price spikes.
Do you guys have a yuge tax on residential propane or something?
o_O
i heard a few friends of mine bought propane in montana for like .84 cents a pound and that's was filling up a 30 pound tank for there RV. i don't know why propane is so damm exspensive out here. i'm on natural gas for the house and genset since it's cheaper. though you can swap out a 30 pound tank for like 20 bucks that would not last me for what i want it for
o_O
Tax here is....8.5208%. On top of all the other charges too. But I stretch this propane out for about the next three months.
i'm just rattling ya cage. though seriously you have code enforcement out there:confused-96:.
When we first built the barn, the county inspector showed up giving us crap about the electric.
Kept saying it all had to be in conduit, needed locate marks, buried cable had to be inspected prior to filling in the trench, etc.
So we waited 8 years & he never came back so we said fuck it.
It requires 18" behind it for some reason.
It's the same as a ceiling fan. You just can't get enough air flow going. The air is used not only for spreading the hot air but to keep the heat exchange cooled down. You should still use the garden hose approach!
I assume it has a blower type fan vs a rotary blade? Damn things will get their air. You can even put a filter on it. It's what vacuum cleaners are.
Who knows? I've never looked closely at the overhead type of heater before. Maybe it's just regular fans.
It's up near the ceiling. In a shop with a low ceiling like 8 feet or less, it's mounted directly to the joists.
But humans stand on the floor. Most of the time.
Therefore the heat needs to be directed downwards. And blown with enough velocity it actually reaches the floor before losing its momentum in a high ceiling application like mine. It would take some pretty powerful conventional fans to do that.
I still think it's going to cost a small fortune to heat that place. Heating up a place that's been sitting for days on end at 15 degrees is going to take a LONG time to heat up. Not sure if this is the right term but stuff just radiates cold from sitting for so long. It's like everything is an ice cube.
My mechanic keeps his whole garage at the same temp 24/7 and it shows. They don't come in and turn the heat up. It's very comfortable. Everything in the place is like 74 degrees. He pretty much gets his heat for free though burning waste oil from his garage and some illegal oil from a construction company.
I remember having a garage at one of my houses a long time ago with a bullet heater. I would leave that thing on for hours then go inside. It didn't matter what, everything was cold. Even the wrenches felt like you were holding ice.
and with a concrete floor, sucking up the outside cold air, radiating it inside. that concrete alone will be cold to walk on. i know, i was in the garage business for 17 years. insulated socks and boots works wonders.
i had to keep my garage furnace on all night long, albeit set to about 65. and this was in a time, when waste oil burners were not available. some garages used wood stoves, located IN the garage, not the office area, which i don't think is too smart. we had a kerosene heater in the office/waiting area, with a door closing off the work area.
there was only so much we could do for the large garage doors as well.....which, frankly, was nothing at all...
While y'all are right that keeping a constant temp will make a shop far more comfortable, the engineer part of me is getting heebie-geebies when y'all talk about 'radiating cold.'
'Cold' is not a measurable thing, it's an absence of heat. So cold things don't radiate cold, they absorb heat. It's why coolers require fans but heaters can be designed to work without them by using convection.
Infrared my boy. Hot objects may radiate, but cold objects absorb. Until they come into a state of equilibrium.
