Ain't doing jack squat til the gas company comes out to bury a line into the building so I can install a heater that doesn't fill the place with fumes.Where is the next chapter of this building project...
Where is the pictures???? Not nice to leave a gal hanging around to watch the progress of such a project....Then disappear like a ghost!!!....![]()
And eat a double helping of beans...I'm surprised you didn't just run a garden hose for the gas!
... Hicksgas has to....
Yes that's the name of the local propane supplier, shut up.......
I'm just wondering what would look better for mounting it.
Steel or wood I mean.
Hicksgas has to....
Its designed to be either directly mounted to the ceiling or suspended with threaded rods.
But I ain't messing with my drop ceiling so I'm going mount it to the wall above the walk-in door that goes outside.
It requires 18" behind it for some reason.
The exhaust flue can only be run 4 feet if horizontal. And I ain't screwing with my ceiling or putting holes in the roof so,.. that should be easy.
WTF bro you came to your sensesAin't doing jack squat til the gas company comes out to bury a line into the building so I can install a heater that doesn't fill the place with fumes.
i bet it will eat through the propaneI wonder how much that costs to run?
.i'm surprized he didn't just run a garden hose for the gas after all he put windows in that you can't openI'm surprised you didn't just run a garden hose for the gas!
.what is this nonsense about what looks better on how the heaters mounted are you gonna be staring at it all dayHicksgas has to....
They have to put a tee on the tank regulator and bury a line from the tank to the barn.
In the meantime I think the Geezer ordered that heater for store pickup.
. i say use a steel mount that way it will hold and stay up in thereThere's certain things I don't redneck.Just set it on one off the pallet rack shelves...
puss...
or I'll call for a vote of no confidence and revoke your redneck card!
Either way it'll be strong enough to hang a car from because that's how I do shit.what is this nonsense about what looks better on how the heaters mounted are you gonna be staring at it all day. i say use a steel mount that way it will hold and stay up in there
your out in the sticks and you have code enforcementEither way it'll be strong enough to hang a car from because that's how I do ****.
I only care about what it would look like to an inspector or something.
how much is propane there![]()
it's 3.64 hereOut here it is $1.94 a gallon also charge of fuel recovery $4.33 and haz mat $5.69. Duck probably pay more he in a rich state.
. only reason i went with a natural gas genset is so i could plumb it right into the natural gas line since gas is cheap out here over anything else. the next genset will be a diesel i can either feed it used veg oil or i can call a heating company and have them deliver a tankful of mixed#1 and #2 wich is cheaper than the on road TAXED diesel
I have common sense. There's certain things I insist be done right.your out in the sticks and you have code enforcement![]()
Amen brother .I have common sense. There's certain things I insist be done right.
i'm just rattling ya cage. though seriously you have code enforcement out thereI have common sense. There's certain things I insist be done right.
