It's translucent plastic.
It's not only translucent, but it also lets light in.
Well if there's a chick outside tall enough you can look up through a 13 foot high window and see her boobies, she's certainly not one you're going to want to piss off.![]()
so do you know this from experienceWell if there's a chick outside tall enough you can look up through a 13 foot high window and see her boobies, she's certainly not one you're going to want to piss off.![]()
Um,... yeah, I do...so do you know this from experience![]()
So, based on this, it's safe to say that it's understandable why your buddies call you a dildo.In fact I've gotten my ass kicked by 50 foot tall women more than once.
OK that raises a question... If there was a 50 foot tall woman, would you climb in there?
I don't know... I'd probably need some sort of breathing apparatus to prevent suffocation.![]()
I told the geezer I needed him to hold the tape measure.
30 minutes later, no Geezer.
So like everything else in this project I had to figure out how to do it entirely by myself.
Yeah if I'd thought of it I coulda had you help measure for the south wall headers even though I didn't have the lumber to fill it yet. Would've taken 20 minutes.You're about 24 hours too late...
DRAMA QUEEN!
Yes.So, let me get this straight on the translucent thingie. You pretty much closed off an already closed off area right?
Basically in addition to making the translucent panels airtight, I added two sheets of plexiglass to essentially make it a triple pane skylight.
It's about keeping heat in without blocking off the light.
i woulda put peanut butter on that.I told the geezer I needed him to hold the tape measure.
with the way you are sealing up that work area, you had better think about a Radon detector....or you're gonna die.Forgot I had this stuff. 36 feet of it. That's enough to save about 3 cans of Great Stuff.
you can have cracks in your flooring, or around the perimeter..you're gonna die..Well for one, radon is a gas that seeps into basements through cracks and stuff in the foundation. This is a pole barn with a cement floor.
Also there will always be a small gap between the rollup door and the opening. The extra effort at making it airtight is not going to accomplish making it 100% airtight.
Also its a drop ceiling. The panels are not caulked.
