Perfectly straight 13 foot 2x6 stud... Attached to the footer perfectly in line with the posts, looking down from the top of the pallet rack. Notice anything?
The 2x4's that hold the steel siding are bowed inward in the middle, about 6 feet below the camera.
Here's looking at the top of the stud, at the 2x6 gap filler thing I'd put between the twin headers.
From the cramped position I was in, that's as far as I could push it...
Until the wind died down.
There was a momentary lull in the wind and it went right in place and stayed put,... for about 10 seconds. Then it suddenly jumped out and bonked me on top of my head while I was lining it up with the pencil marks and screw in the bracket. :mad:
I didn't think wind pressed inward on the walls that much.
Especially since that's the first stud, only two feet from a post. :confused:
what no pole for the pole dancers:confused-96::D
Kerosene fumes are making me sick.
And that's with about 33 square feet of open gaps I have yet to close off. Plenty of fresh air coming in.
The only upside is once I close that stuff off, I won't have to run the heater as much.
The plan is to eventually have a thermostatically controlled LP furnace like a house. No emissions (inside) and it'll be a lot quieter and I wont have to blast the stereo.
Buddy Series - Heaters - Product, Price $100.00 and above
stop being such a tight ass and get you one of these
Worked non-stop for 14 hours today. :eek:
The wall-to-pallet-rack-to-ceiling connection is done though.
And it's all airtight. In fact, after the caulk is all completely cured I could probably fill that very top shelf with water and it won't leak. :toothpick:
... which is probably a bad thing if the roof ever leaks.
:stare1:
Why is that top part all enclosed?
Space, mainly. I'd only have 11 inches of vertical space above that top shelf if I ran the ceiling all the way to the north wall.
This way I've got more vertical space on the very top shelf. It's 8 feet in the middle.
And because the uprights for the pallet rack have diagonal gussets in the part that extends above the rafters, so it's unwise to cut them down,.. meaning that it would be a major pain in the ass to build a ceiling through it.
Access to the top shelf is easy with a ladder on the other side.
