After 8 years in the east barn, full of kerosene all I had to do was dump out the old fuel, vacuum out the mice nests (hood thing I took the top off before even testing the fan) and replace the dry rotted fuel lines. It fired right up.
125,000 BTU.
My dad shined it up like new while I was out getting kerosene.
F***ing 5 dollars a gallon at the truck stop in Manteno :mad:
125,000 BTU.
do you have home heating oil companies near you.>??
many do carry K-1 as well, with a pump on the property, this is where i'd get my K-1
This thing was my grandpa's.
It's not compound. It can miter (rotate on vertical axis) but not bevel (tilt on horizontal axis).
It's cross-cut ability is just shy of 5 inches. Therefore it takes two attempts to get through a 2x6.
To greatly speed up the process of framing out 2x6 exterior walls, I convinced my dad we needed this:
It's a compound sliding miter saw. Because of the sliding action, it's cross-cut ability is 12".
Ok,... that was yesterday.
My dad just came in here and bitched because I was using my handheld circular saw to cut plywood.
:bonk:
Example, that strip closing off the top shelf here. . . . that's 12" by 98-3/4". That's what I was using the circular saw for. :rolleyes:
Last night I was up on that top rack trying to get an 8 foot 2x2 furring strip to lie flat along the front edge of the shelf to have something to screw the plywood to at the bottom.
It wouldn't fit so I handed it down to him and told him to trim about a blade width off of one end.
He walked over to the table saw instead of the miter saw. o_O
The man has TWO bachelor's degrees and a PhD. :stare1:
125,000 BTU.
125,000 BTU's British Thermal Units? What does that work out to in American?
Is that your bedroom closed off at the top?
That's the doghouse. :toothpick:
For when Mrs Duck is crabby. :D
Actually I don't know what to do with that space. Making a sleeper berth up there is certainly a possibility but I think it'll end up too narrow because of the insulation. And I certainly don't want to sleep next to fiberglass insulation unless there's an airtight barrier around it. I'm all itchy just from crawling around up there today.
