I forgot, you should have greased up your nuts also. Moisture gets in there and that's not a good thing. Usually greasing your nuts is a two person job. This is a job many women can help with and actually like doing. Since Injun is an OTR trucker maybe she could help. Have her hold onto your nuts tightly while you shove grease in there or you could hold your own nuts and she could grease them up. Probably better if she greased them. Her hands are smaller and can get in between your nuts better.
Hope this helps. Gotta go shave my ears now.
Ok now I'm going to try making two windows from scratch.
Tomorrow.
Cuz it's too flippin' cold to do it now. :mad:
Set the blade depth only what's needed. You really should have a blade for cutting it and not a plywood rip blade.
Bob Vila dot com or whatever said to use a blade made for plastic or one made for metal.
I got one that says it's for OSB, plywood and plastic.
