Looking at my order history, I did actually order two of the correct filters a while ago but the one I found easily was sent as the wrong one. But it's been too long to rectify it. I found the other one. It fell (got pushed) off my shelf. Still in the box and in perfect condition thankfully. That one looks to be correct.
Replaced the water separator filter on the pickup ahead of the storm. Dumped a bunch of anti-gel in both tanks. Not sure if that will solve the issue but it's at least a start.
If it's not just poor maintenance on my part then I have some research to do.
Could their be something getting sucked up into your fuel line?
I'm starting to question the glow plug controller. Like it won't fire if it's cold. She fires up just fine and quick right after it's been shut off and is still warm/hot.
I already put a set of new OEM glow plugs in it.
I have that electric primer pump to make sure it's not fuel starved, even if it has lost its prime from sitting or I need to refill the filters from changing them.
Bitter cold morning, but in the interest of greed press on and go to the rail. Get to the rail and under my trailer, to see the tandems are all the way back. Gotta slide 'em. No big deal unless the pins are seized (it's an old one) but they come out with a few yanks. Cool.
Go to crank landing gear. On a bind. Visibly so. Get back in the truck and slam it rearward to get the bind out. Works good enough to get the legs up with a bit of effort in slow mode (it was also dropped flush so my truck didn't lift it). Legs are finally up. Get back in the truck to slide the tandems.
Whole rear end moves. Wait. Am I sliding on ice? Pull forward and all the way out of the hole onto dry pavement. Nope. It has no brakes. I pump them. Doesn't do much if anything to self adjust.
Manage to get it to slide about halfway using the spike but then there's friction and it rolls again. Lock in the pins as they are since that's all I can get out of it.
Put it back in the parking hole. Call dispatch. Go home.
It's not worth more than that. I don't have my brake adjustment tools and I don't like messing with that on their stuff anyway.
It's an OLD POS chassis and might have been even more trouble once down the road.
It's still cold but it warmed up just enough to finally replace my 7 way. It's been sloppy for a while, but I've been wedging it so it's fine. But the last straw was the screw somehow falling out and the housing coming apart in my hands. Annoying.
I rewired the end of one of those plugs just to see if I could do it.
I did it. Would not recommend. Better to do like you did and get a new cord.
Today was the first day with the new plug and nothing caught fire so I think I got it right.
Holy crap a new 7 way fits tight though. Or maybe being cheapo Chinese it's fatter than it should be. Let's go with that, instead of that I'm a weakass.
I'm probably actually a weak ass. It was only a sample of 2 but the grip was pretty serious and I didn't have any play where the lights would and wouldn't work.
It's great. For connectivity. And not falling apart in your hands.
Wish I was OTR and hung on to the same trailer for at least a couple days at a time though. Still fantasize about having my own air ride trailer.
I watch the suspensions of these air rides bouncing all fast while the trailer itself doesn't move much. Then I see the spring rides where the whole thing bounces fast. And I'm the bounces fast. It sucks. I'm tired.
I think I'm burnt out despite having the sleeper. It's better than the day cab but it's still suckage.
