Waddaya mean judge? It was a question.
Well I didn't use it at all last year because everything melted before it mattered. This is the first I've had it out this year, otherwise I'd have known it wasn't running.
So I guess it just depends how much we have and whether it's sticking around if I'm gonna get it out.
I generally hate shoveling either way, but there are bits I have no choice.
My neighbor asked me yesterday if he could borrow it today and I had to tell him it wasn't running. He wanted it for his concrete rear deck/patio because it's a big area. I was glad to be able to tell him it's available when he gets home from work, especially since he cleared my sidewalk, which also helps get the Mack out.
Got the snowblower running again. My push mower carb is basically the same except the choke setup. I couldn't get the choke arm off the old one so I pulled the bowl off, took the float and pins out, cleaned it up as best as I could, then used the float pins bowl, etc from the new spare.
The old fuel drained out naturally when I took the hose off.
Put it back together, put fresh gas in it, and it fired right up.
Cub Cadet. That's like top of the line right?
So this is my blind spot sensor harness plug. The wire broke off where it's circled. Right up against. No room for splicing.
Did some digging around and found a Volvo cars plug that looked the same on eBay for $20 shipped.
Finally got it yesterday and put it on today. And it works.
I tried to get the truck out and it slipped sideways exactly the way I thought/feared it would. Fortunately it didn't go off the side and I got it back, but it's about a foot over from where it usually sits.
I shoveled some more and laid down some salt. Hopefully it breaks down enough to go sometime soon, but I'm not going to rush it.
I'm sooooo risk averse these days. The money just ain't that hot.
Had better success getting the pickup out. Which is good because I needed some basics again. Dollar General is right around the corner. Having the bed full of snow certainly helped with traction.
I still want something 4WD/AWD instead of a cheap 2WD sedan I think. Probably not as urgent though. Especially if I got myself some dedicated snow tires.
