Electric Chicken
I'm thinking this spring, or one good warm day when I'm in the mood this winter, I'm going to relocate the electric fuel primer pump switch to inside the cab.
Only reason I didn't do it when I first installed it was laziness. It was easier to just run it where it is because the pump is under the hood on the fender, and I was simply replacing some janky old gator clips that eventually broke. Routing back to the cab and then back out of the cab was extra work I didn't feel like doing at the time.
That said, I used it before initial start this evening after sitting around and it made a big difference getting it to fire. I didn't have to use the half throttle trickery outlined on the visor and it cranked a lot less.
If I move the switch in cab I can use it as a matter of routine and put that much less stress on my batteries and starter.
I don't think it has the duty cycle to run with the ignition. I suppose I could get an inline one that does and run it that way. But the mechanical works fine when it hasn't lost prime.
