Electric Chicken
Also bonus, the app also automatically recognized the 4x6 shipping label printer I recently purchased to replace my 20+ year old Zebra.
I dunno it just does what it does.Good deal, but I think 160 is a little cool to completely burn the fuel.
Cooler engine= cooler intake air temps = denser fuel air charge = more sustainable power for not much more fuel. Personally I wouldn't want to see it below 160. That might swing the scale too far the other way.I seem to be pretty firmly in the mid to high 6s for fuel mileage again with better climbing power. Maintained 60mph over both hills between Hagerstown and Frederick on I-70 and was loaded both ways. Empty I'd still be down to 50mph and I just figured it was the tall gearing. A couple times I didn't even get a run up. I was just cruising at 62 and it didn't go below 60.
I probably said it already but I'm thinking the truck was gradually derating the horsepower to protect itself as the coolant filter clogged and reduced flow. Because it really woke the hell up and it takes a lot more to get temps up to 200. It stays between 160 and 180 a lot more now.
Thanks for clearing that up. I remember driving trucks with pyrometers and a switch for the engine fan. I never knew what a pyrometer was for. I just remember my uncle telling me to hit the fan switch on the way down the hill and turn it off at the bottom before ascending the next hill.Cooler engine= cooler intake air temps = denser fuel air charge = more sustainable power for not much more fuel. Personally I wouldn't want to see it below 160. That might swing the scale too far the other way.
I'm in a 65mph company truck. I love getting passed by the same truck 4 times in a few hours. I wave as they go by. Again and again. Much like you I try to handle all my business in one stop and keep moving.Do you really think that running the hills will slow you down that much? I seriously doubt it. Opening that left door all the time is what slows you down. I used to love to watch those 80mph runners blow my doors off, then a few hours later blow my doors off again and then again even further up the road and I'm still chugging along at 70. About the only thing I stopped for was fuel. Even then, it was fuel, food and bathroom and back out there.
I've gotten pretty decent at local trip planning and knowing what my truck is capable of.Do you really think that running the hills will slow you down that much? I seriously doubt it. Opening that left door all the time is what slows you down. I used to love to watch those 80mph runners blow my doors off, then a few hours later blow my doors off again and then again even further up the road and I'm still chugging along at 70. About the only thing I stopped for was fuel. Even then, it was fuel, food and bathroom and back out there.
It's about what you can do in one day without having your house on your back just in case things go awry.But you aren't pulling them any slower than the guy that just passed you with the 4mpg 600 under the hood.![]()
History lesson:Cooler engine= cooler intake air temps = denser fuel air charge = more sustainable power for not much more fuel. Personally I wouldn't want to see it below 160. That might swing the scale too far the other way.
No they put the dinosaur directly into the crankcase.History lesson:
I have a tractor that was built during WW2.
Back then they didn't have glycol antifreeze yet, so they used alcohol.
They constantly had to keep adjusting the water/alcohol ratio because the alcohol would evaporate.
So on my tractor, they used a 160°F thermostat.
Problem - in hot engines cooling down, condensation gets inside the engine block and it ends up in the oil.
In a modern vehicle, that condensate boils out of the oil and evaporates & gets blown out the crankcase breather.
But in the ancient tractor built in 1945, with that 160°F thermostat, the oil never gets hot enough to boil out the water.
The result is sludge buildup inside the engine.
Since I run regular modern antifreeze in the tractor, I put in a 180°F thermostat, which is the hottest one I can find for it. I'd prefer 190°F because that's the temperature that modern oil is made for.
It's a flathead 4 cylinder, 122 cubic inches, 26 hp (originally) gas engine but I run 15w-40 diesel truck oil in it.
No more sludge in the engine, but the transmission/differential/rear PTO oil still gets condensation in it. Especially when I'm running it in the winter plowing snow.
I forgot the point I was trying to make.
Oh yeah, you said you don't want to see truck engine temps under 160°. Just figured you'd like that little bit of tractor history.
Running a truck too cold down a grade ain't gonna cause water in the oil because it'll heat back up. But the oil is designed to work best around 190-200°F
I don't know what kind of oil they might've used in 1945. Did they even have oil refineries back then?![]()
