Or die trying.Bench press one of those a few times and I'ma stayin away from you!
They have it and can match up OEM. It's worth the aggravation.If it needs new ujoints I'll have them preload a pair so we can just lift this thing up into place and put the clips on. I don't really want to mess with this thing to put the ujoints in myself.
Yep they're also going to supply new bolts if it doesn't need ujoints which include them.They have it and can match up OEM. It's worth the aggravation.
Yep. If I had NO idea what it was and needed a diagnosis, I'd go to the dealer.No argument from me. The line of people it has to go through, get the job done, call you, you pick it up...Here's the D/S, fix it. Going to a dealer or a shop like a dealer is like going to a seafood house and ordering a Porter House. You do chassis and driveline work only, not A/C and interior work.
That's venturing into 1/2" territory. The seller/manufacturer must have some faith in the product.The one I ordered has a 20 inch handle. My SO is the 10 inch FL80 (I think).
So I ordered a new extractor set. Exact same one. I damaged it hammering it on because I had to alternate hitting the corner and not really straight on but kind of to get it to actually go straight on. That created burrs that I cut my hands on. I can grind them off but the tool still won't be the same.
I figure the fact that it did an excellent job makes it worth getting another set since they don't sell singles. It's also a cheap set. But it did excellent unlike other cheap sets I've had. I was pleased to see it's actually $5cheaperless expensive than when I previously bought it. Hopefully it's not also cheaper.
Yeah the ones you hammer into a fastener to dig into whatever metal is left. They're undersized to bite. It was actually difficult to hammer on partly because the bolt was in good condition, just with no teeth.That's venturing into 1/2" territory. The seller/manufacturer must have some faith in the product.
Screw/bolt extractor, I ASSume. I couldn't get by without it, working on 50-80 year old vehicles. Especially those from the rust belt.
Dude...Don't look out the back window then. It's a catwalk that you climb all over with dirty, muddy, snowy, salty boots.I think I just convinced myself to replace all the decking. The one closest to the 5th wheel is the "new" one and I didn't realize how badly worn my original stuff really was.
Nah they're basically collapsing. I straightened it all out once. I think big boy previous driver took the rigidity out.Dude...Don't look out the back window then. It's a catwalk that you climb all over with dirty, muddy, snowy, salty boots.
Go get some brightener and do the deck, steps, tanks and then polish it all out. You just like spending money.
