Reptar
If Rockefeller was still alive he'd tell you they lost certainly had refineries.History lesson:
I have a tractor that was built during WW2.
Back then they didn't have glycol antifreeze yet, so they used alcohol.
They constantly had to keep adjusting the water/alcohol ratio because the alcohol would evaporate.
So on my tractor, they used a 160°F thermostat.
Problem - in hot engines cooling down, condensation gets inside the engine block and it ends up in the oil.
In a modern vehicle, that condensate boils out of the oil and evaporates & gets blown out the crankcase breather.
But in the ancient tractor built in 1945, with that 160°F thermostat, the oil never gets hot enough to boil out the water.
The result is sludge buildup inside the engine.
Since I run regular modern antifreeze in the tractor, I put in a 180°F thermostat, which is the hottest one I can find for it. I'd prefer 190°F because that's the temperature that modern oil is made for.
It's a flathead 4 cylinder, 122 cubic inches, 26 hp (originally) gas engine but I run 15w-40 diesel truck oil in it.
No more sludge in the engine, but the transmission/differential/rear PTO oil still gets condensation in it. Especially when I'm running it in the winter plowing snow.
I forgot the point I was trying to make.
Oh yeah, you said you don't want to see truck engine temps under 160°. Just figured you'd like that little bit of tractor history.
Running a truck too cold down a grade ain't gonna cause water in the oil because it'll heat back up. But the oil is designed to work best around 190-200°F
I don't know what kind of oil they might've used in 1945. Did they even have oil refineries back then?![]()
That's a cool piece of history. I did know they used to use alcohol as coolant and propane as refrigerants, bet that stuff back then didn't come with a warning sticker on the vehicle for it either.
FUCK
