I just plowed snow.
I'm going to need to add a page to the 1946 Ford tractor operators manual:
How to start this 70 year old machine when it's below zero....
1. Don't even bother hitting the starter even if the 6 volt battery is brand new. Just dump 180 amps into it with the booster. It'll only accept maybe 30 amps anyway.. Until to you hit the starter.
2. While it's quick-charging, put a 125,000 BTU torpedo heater two feet from the engine block, on the carburetor side.
Wait ten minutes.
3. Half throttle, full choke, step on the clutch, key on, hold down the on the starter button & wiggle the shifter lever until it figures out it's in neutral...
Exactly three seconds after ignition, no sooner, no later, reduce choke to 2/3rds.
Make sure PTO is disengaged, then carefully let go of the clutch.
Get off and move torpedo heater so it blows in between the loader bucket and the front of the tractor so the fan that runs full time, draws warm air through the radiator. Make sure the pump for the loader hydraulics is also getting blasted with heat.
As soon as loader begins to work, run it up and down continuously to circulate the frozen hydraulic oil through the super hot pump to thaw out the whole system.
Then engage PTO.
Ten minutes later when the grader blade eventually lifts off the ground, move torpedo heater around to the rear and point it underneath the rear axle to warm the sump for the shared transmission/PTO/differential oil. When you see smoke coming from the oil and grease on the bottom of the machine, move torpedo heater back to the front. Raise loader up, and position heater to blow directly into the "cooling" fan. Periodically remove a glove and check the cylinder head for heat. If it's too hot to touch, you can put cardboard over the front of the grille and operate the tractor for ten minutes.
After ten minutes or when loader hydraulics quit working, whichever comes first, bring tractor back by the heater and warm up the pump again. If cylinder head has cooled back down, as soon as loader starts functioning again, raise it up so you can remove the cardboard and point the heater directly into the radiator until engine reaches normal operating temperature again.
2 cups of kerosene in the hydraulic system will extend the time between system warm-ups by about 20 minutes.
