I'm halfway through the LP gas conversion. Then I got lazy and decided to go inside.
I changed out the orifices brass things that spray the gas into the burner tubes.
But I didn't change the diaphragm spring in the regulator.
Damn gas company won't come out and bury the friggin gas line until the heater is completely ready to run.
I already decided I ain't going to do the exhaust piping because that shit doesn't make any sense.
HVAC company won't come install the exhaust if there's no gas connection so they can test their work.
FUCKING STUPID ASS PEOPLE.
:gun3:
I'm just going to run a flexible gas line across the yard, do the hookup myself with a 40 dollar regulator from Menard's, tell the HVAC douchebag the gas company did it like that because it's too muddy to dig (they actually do that in real life :confused:) and if that's not good enough for the HVAC dick heads I'll just run flex out the wall and surround it with "fireblock" Great Stuff.
I need fucking heat in there and I'm sick and tired of dealing with bullshit. :mad:
I'm confused. The only thing your missing is running the exhaust outside? That would take me 1/2 an hour. What's your problem?!?!?
The ductwork pieces they have at Menard's the ones that don't cost $50 per foot, don't seal up anywhere close to airtight but nothing I've found online mentions anything about needing a 5 gallon bucket of high temperature sealant.
Can't figure out for sure if I need a condensation trap, and still don't know if my exhaust gas temp is below 480° so I can use a silicone boot on the pipe where it exits the steel siding.
Also even with double wall duct, because I can't find any data on EGT I can't determine the clearance to combustible materials for a standard wall thimble through the plywood only 2-1/2 feet from the heater.
Decided I'm going to get a piece of sheet rock for the 3x3 ft section of interior wall it'll go through instead of plywood.
You could get a thick piece of something, even wood maybe 1'x1'. Cut it in half. On each half make a kerf cut on the side. One of them make it deeper. Make a normal kerf cut on the bottom of both pieces. Make a deep kerf cut on the top of both. Make a hole in the middle for a section of Metalbestos then run your exhaust through that.
Huh? :confused-96:
Ain't following. Draw a picture & post a photo of it.
I'm thinking I'm just going to frame out an 8" ID square in the wall with sheet metal studs, attach the wall thimble to it, shove a pipe through to mark the hole to be cut in the siding, make that hole, remove the thimble, then wall it off on the inside with sheet rock. Just a 3x3 foot section. Put an 8" hole in the sheet rock, put the thimble back on over that hole, and stick the pipe through it.
I'll leave out the horizontal stud at the top of that sheet rock section so it's open.
Get the gas man to bury the service line. After he leaves I can run the heater and monitor the EGT and flue temp and decide what kind of sealant to use.
I'll stuff insulation in the wall after pulling the paper backing off, then monitor the pipe temp again. Eventually put the horizontal stud in & seal up the outside hole however I figure out how to do it.
Probably get one of those lead sheet metal things and just caulk the hell out of it.
Coincidentally, the highest temp rated "stove sealant" I saw at Menard's was red. So it won't look too horrible on the red barn.
Ok, here is half the block of wood. The blue pen marks are the dado depth on the side and the top. They are there so you can first lift the board up enough so you can get the bottom part in. The top dado is a lot deeper then the bottom. The side dado is deep also so you can slide it way to the left so you have room to get the right side in. Then close the doors and screw some metal whatever to hold it shut. Caulk on the outside. Through the hole put a small section of Metalbestos. If you don't know what that is look it up. Put your standard pie plate cover on both sides.
You can use 2" x 12" boards. Screw 2 together to make it thick enough or 3. Whatever you need. The dado has to be big enough as the thickness of your corrugated siding.
It's simple and will work and look good.
Still kinda confusing but I think I get what you're saying.
The wood serves kind of like a grommet between the thimble and the steel siding,and the metalbestos (AKA double wall duct pipe) is like the wire.
I'd have to use pressure treated wood.
And install it rotated 45° like a diamond shape so rain runs out of it better.
The Metalbestos pipe is just like any other stove pipe but it's really insulated and can go through a wood house wall without anything else. You can even put your hands on it when a stove is running.
You don't have to put it like a triangle. There is plenty of room to put that expanding foam in there since it won't be hot. The chrome pie plates will cover it up.
Yes! A grommet. Not sure what you mean about the thimble
Yes, something like that. The pie plate is decorative. It just slides onto the pipe outside and inside and covers any gaps around the pipe. It's not like your putting a hole through an 18th century Victorian house. It's freaking metal barn. Just make a hole and use one of those thimbles and be done with it.
You're pissing me off!
Before you quit trucking you said your next gig was going to be farming.
I gave you a pass on returning to the geek squad since it was your former profession but now that you're getting all up in the fabrication binuzz I believe I have a valid grievance.
Either you agree to abstain from tequila until inauguration day or we go to arbitration at the next monthly meeting of the Peckerwood club.
Your choice!
:harumph:
I say get two 1" plates of steel. Drill holes in them for 1" bolts. Put one plate on the outside and one on the inside. Put the nuts and bolts on and get out the 250psi air gun and crank it down till it's flat as a pancake.
