My god, you are such a nerd..
Because I can't get it out of the east barn, that's why.Why not just use a router?
Toldya. Gotta over complicate it.Because I can't get it out of the east barn, that's why.
I made a miter saw table on top of a 5 for wide dresser when I was about 19 or so.
It's also in the east barn.
Grandpa's router is attached to a table on wheels thing he made. (just like he did with the planer).
There's a lean-to on the east side of the east barn with a sliding door at it's north end.
The corner post, some jackass hollowed out a rectangular hole at some point in time, or maybe it was for a peg joint that never got used. That whole barn is framed with timbers & they're carved so they don't need any steel hardware at the joints. I don't know what the term for that is, but the Amish still build barns that way.
Anyway that corner post broke right at that weak spot & the whole corner of the barn collapsed about 3 inches or so.
As a result, that sliding door is jammed into the ground at the bottom and won't open.
Coincidentally, the track at the top, the part it slides into when it's open, fell down because the wood rotted. There's nothing I can reattach it to. I'd have to build a new section of wall just to have something to bolt it to.
So anything too big to carry out through the little walk-through door into the main part of the barn (and through my dad's giant heaps of kites & bicycles to get to the west door) is trapped in there until I figure out how to fix that corner post.
Wind blew one of the corn crib's sliding doors off the track a couple weeks ago and I was able to hold it up while my dad guided the rollers into the track from atop a ladder but it was a pain in the ass. I suppose if we REALLY needed to get something out of there I could just jack up that broken post & we can take the door off the track....
Instead I just walked in there with a 9/16" and took the miter saw off the dresser and made a new table.
As for the router though,.. I can just use my circular saw to notch stuff. I don't foresee having any use for it, like EVER... It's only value is sentimental because it was my grandpa's. It wasn't just crap he happened to own either. Woodworking was his thing. That's pretty much all he did when he retired. Except mowing his lawn every two days... High end stuff too, not the rough framing type of thing I'm doing.
Let's see, rebuild structural stuff in the barn and mess with that stupid door, or just set the depth on my circular saw.... Yeah my way was REAL complicated.Toldya. Gotta over complicate it.
An all ya wanted was ta grab th' router. Uh-huh.Let's see, rebuild structural stuff in the barn and mess with that stupid door, or just set the depth on my circular saw.... Yeah my way was REAL complicated.![]()
I just made a run for smokes. I saw what appeared to be an old geezer in the ditch on Rt 50 with a 2wd F-150 so I whipped a U-turn. No snow or anything to explain the ditching so I figured I'd go check to see if he's having a stroke or something. Didn't look like there was any damage, but he was sunk in the mud to his frame.An all ya wanted was ta grab th' router. Uh-huh.
nah, each piece of machinery needed a motor, and work bench. no time for that crappola.Your dad's crap was probably QUALITY MADE IN USA stuff with actual BEARINGS and STEEL parts. Your "lightweight" crap is Chinese and it's only lightweight because it's made of PLASTIC.
You should've given away your own crap and kept your dad's.
You mean a bench grinder that uses an external motor that drives it via belt?nah, each piece of machinery needed a motor, and work bench. no time for that crappola.
better to have cheap Sears tools than heavy weight things.
Yeah that's exactly what I was describing. Except that particular joint has dowels going through it to lock it together.Them joints? Mortise and tenion joint.
https://www.google.com/url?sa=t&sou...5VVgV6p57hjdiVqyQ&sig2=w6Y5NQ5bi8TF-4nkoaHu6w
yes, each device, needed it's own bench (usually wooden which dad and his bro built), then below the bench, on a shelf, a motor had to be bolted down, then a fan belt to run the machines. then they'd shim the motors if needed, for belt adjustments.You mean a bench grinder that uses an external motor that drives it via belt?
My dad had one like that.
It had those little clap-trap things you lift up to put oil on the bearings. Keep it oiled & it lasts forever. Today it's either loose, sloppy Chinese "permanently lubricated" junk or it's just a steel shaft spinning in a nylon bushing.
Yep, that's how ya lock the joint.Yeah that's exactly what I was describing. Except that particular joint has dowels going through it to lock it together.
What are you doing !?!?!?!?!?
Don't we have a spare black cat that likes to prance around under ladders around here somewhere?Apparently devising a way to fall off a ladder!
@Duck****ty plywood.
But whatever. There's progress.
Getting the upper sheets in place 100% by myself requires every cuss word ever used in history, including their substitutes like "dang" and "fuggin'".
But at least I haven't fallen off the ladder yet.![]()
