He's gittin' ready ta hunker down fer th' next four years until Ms Satan leaves th' White House.
In the picture that prompted @Skateboard to ask the question first, I think it's pretty clear I'm building a wall.
Because Trump. :cool:
The structure of the wall is a 14 foot tall pallet rack. I'm just covering one side with plywood, basically. When I'm done with that I'm gonna start on a drop ceiling.
yes your building your man cave we know that :D
umm. you did...????
That was a reply to a comment about the abnormally tall door threshold.
It's a residential exterior door. Like one that opens into a living room with padded carpet right inside the door.
Ain't no carpet going in my workshop. Though I might paint the cement floor gray.
There should have been an 8' ceiling max. Your not going to heat that massive area and no insulation. You could but you will have to leave a blast furnace running non stop. My last house had a nice wood shop in the basement that I closed off with a wall. There was a forced hot water line running through it. I was able to just add about 2' of fins and that was enough to heat the room.
8 feet is unacceptable for a workshop. I need head room.
The rafters are 14 foot. I'm going to put the drop ceiling at 13 ft 4-1/2".
With the 1" thick ceiling tiles, plus ten inches of insulation, the top of the insulation will be flush with the top edges of the rafters so I can see to step across them if I have to get up there for some reason. I'll probably unroll that reflective bubble wrap across the top of the insulation too.
I'll probably make some catwalks around the light fixtures for maintenance access.
But I want a high ceiling.
I have several ceiling fans I can put up too. Set em on low, blowing downward.
Not a big deal.
Yeah it'll take a lot to heat it at first, but the project isn't done until the whole thing is insulated.
The Geezer measured the distance between those knots and did some calculator stuff & said the outer ply was shaved off a tree that was 7.64 inches in diameter.
"That's real helpful, Dad... Hand me that level."
Now he's making himself useful by looking up the name of the guy who did the drums in In A Gada Da Vida. Because..... :dunno:
This is actually working.
The steel feels about 120° because the sun is shining on the other side. Blowing air onto it is actually heating the workshop a tiny bit even though there's no ceiling yet & the heat rises right out through the ridge vent.
