Well that Husqvarna mower I replaced the deck on a while ago came back.
"Engine smokes a little"....
I got it home and fired it up. Just fine for a minute, then it's pure air show smoke. I mean smoke so thick you can't see through it even after its drifted 20 feet away...
I shut it off, waited a minute and checked the oil.
WAY over full & smells like gas.
Bingo,.... stuck float. Flooded the carb & filled the CC through the breather tube.
Oil in the air filter housing. Just fer the hell of it I did an experiment. Removed air cleaner housing and left the crankcase breather disconnected & fired it up..
Still a smoke show, not nearly as bad but it was squirting black gasoline about two feet out the breather tube.
So I changed the oil. Rigged an air hose to the crankcase breather tube and left my compressor blowing 10 psi into it. It was blowing vapors out the oil filler & drain holes for a few minutes.
Put new oil in & fired it up.
No smoke at first, then it started smoking again, nowhere near as bad but I was thinking maybe the rings were glazed or something. I'm not dissecting the engine unless I'm sure.
As soon as it warmed up, it quit smoking.
Guessing maybe the muffler was full of oily gas and had to burn off.
Oil capacity is 1 quart.
It almost completely filled a half gallon juice bottle. And it was not oil with gas, it was gas with oil. Looks like truck stop coffee. Extra bold. Same consistency too.
I'm letting it cool down then I'm gonna investigate the float.
Probably a pinhole, broken solder joint if it's brass, or maybe it has one of those rubber tipped float needles and today's ethanol gas ate it up.
But if I need parts I'm installing a shutoff on the fuel line.
