Geezer is on his way home from Missouri (allegedly). If he remembered to bring his GPS he might be back in town before Menard's closes.
The door has it's outer molding already attached. With big staples sunk below the surface. I would break it trying to get it off.
So I gotta get the plywood up first or it'll look stupid.
I mean stupider than a door installed in a plywood wall that's clamped to a pallet rack. :rolleyes:
I took that angle iron thing off this morning, washed the drilling oil off in the bathroom sink with dish soap and painted it.
I've gotten pretty good at installing steel brackets while the paint is still wet. :D
I also tack welded a washer to that little plate that distributes the pressure on the hollow pallet rack beam. The washer simply keeps the plate centered on the end of the bolt so it doesn't slip when I tighten it.
I got the two piece 14 foot stud so straight & the top and bottom so perfectly centered that removing & reinstalling that clamp didn't change the 38" door opening width at all.
It's spaced on the 4's.
Meaning the center of the next stud east is 4 ft from the center of the door post.
Meaning the plywood won't reach the inner edge of the door opening. :rolleyes:
Coincidentally, the molding on the door will overlap the stud halfway. So I didn't need to go get plywood yet.
Whatever though.
Cutting raft styrofoam with a circular saw is the easiest way,.... but probably the messiest.
Too lazy to make room to set up saw horses, I set the blade depth to the same thickness as the polystyrene so I can cut it while it's still on the stack on the trailer. ;)
Well. Got one 4x8 section done.
I think.
Might get some kind of spray-on fire retardant for that exposed styrofoam. Gotta be white though. For lightning. Probably spray paint the styrofoam a pale gray before spraying white fire retardant on it so I can make sure I get full coverage.
Unless I can just jam some sheet metal in there.
I can't tell but the gap on the bottom looks really big. Did you know your suppose to trim those 2 boards on either side? Not really important though.
WTF are you talking about? Gap on the...
OK you're just trying to confuse me now. :mad:
I think.
In this picture it looks like there's a 5" gap at the bottom. May just be the picture
No. They make the side rails really long and meant to be trimmed depending on the height of the threshold used.
Only the door? No, the threshold is gray. It's flush with the bottom of the side boards. It just blends in with the floor in the picture.
If yer talking about the gap on the bottom of the lower styrofoam panel, there's no gap. It looks odd because it's on top of a 2x4 that's laid on it's edge, but screwed to another one lying flat on the floor and bolted down.
For the majority of the wall, the footer is on its edge and secured with L clips screwed to the floor. I only have the ones laid flat around the door because I needed to secure it better.
The footer us on its edge because I don't want the bottom of the plywood touching the cement. It'll start rotting in the summer when it's wet from condensation.
Having it on edge let's me set the plywood 1-3/4" off the floor and still have half the footer board to screw it to.
The footer boards are pressure treated.
@Skateboard
Yeah there's a gap under that styrofoam. But not 5".
Cutting styrofoam sheet with a circular saw isn't exactly a precision thing... I erred on the side of cutting it too small. Cuz to trim off a little tiny bit of excess is probably impossible.
I have a hot wire cutter somewhere.
Operative word being "somewhere". :mad:
After some initial confusion I laid the door flat on the floor and put a square on the corners of the frame and found that the knob plunger thing doesn't center in the hole in the strike plate if the door frame is held perfectly square.
There is a router cutout where the strike plate goes & no wiggle room.
So instead of trying to figure out how to get my router out of the east barn and through a door that's stuck shut, then having ugliness around the strike plate, I simply installed the door frame slightly out of square to compensate while keeping the threshold flat on the floor. No problem but it required shims on both sides.
Opens & closes perfectly.
When it's open, the door would "fall" closed.
Then I closed the roll-up door to stop the wind and now it stays put wherever you leave it. :thumbsup:
Next step, figuring out how to haul a ton of plywood home from Plainfield with my car & a trailer rated for 1000 lbs.
Geezer's S-10 engine is blown and my trucks aren't legal to drive. :(
Get some invisibility paint... they'll never notice ya!
