It's that big pallet rack thing a few pages back. I'm building a wall against one side of it to close off the rear 20-something feet for a heatable workshop.
Maybe I'll make a sleeper berth on one of the top shelves for when I'm in the doghouse. :)
So your going to put in a change of address to the barn. Tried thinking of a day you weren't in trouble.....got nothing:dunno:
Actually I've been thinking about converting the corn crib into a man cave.
There's a 1 car garage underneath where they'd pull trucks inside to fill them with corn. There are 3 rooms on the 2nd floor and then there's an attic above it where the women would husk the corn and drop it through the trap doors.
The crib started to fall over at some point because the nails in all the X-bracing rusted through, but somebody saved it by replacing the nails with bolts. However the whole barn is slightly askew. Top leaning east a little bit. That would make the siding on the north & south sides a major pain in the ass cuz I won't be able to use a level or plumb line for anything.
I anchored that wall beside where the door is gonna go.
I'd never put fasteners in concrete before.
$35 hammer drill from Harbor Freight.
Rock solid now. :)
Can't work on it any more tonight though.
Whatever source of energy I found yesterday that kept me busy for 12 hours non-stop without a break, didn't come back today.
Anyone ever install a pre-hung door in a new construction? (not a replacement)
It measures 37-1/2" wide.
Since I haven't framed it out yet I'm wondering if I should frame the opening exactly 37-1/2 wide or make it 38" & shim it.
I can put the hinge side post perfectly plumb vertical at any exact distance from the other because of the way I'm clamping the studs to the pallet rack at the top. Just tap it with a hammer til it's perfect.
I installed the knob in the door. Noticed that the door doesn't open & close properly because it's frame isn't locked square. Also with nothing holding the latch side flat, there's too much gap between the strike plate and the door, so it won't stay closed.
That's why I'm thinking I should make the door opening a little wider so I can fine tune it with shims?
It would give me an excuse to go back to the hardware store to get shims. :toothpick:
I don't think the cement floor is 100% level and I don't want any gaps under the PLASTIC threshold. And I can't have the door frame skewed or it won't close right. I might have to install the door slightly crooked on purpose.
If you can get the hinge side plumb, fasten that side and shim the other side.
Leave 1/4 "gap and shim. Use 1 shim each way.so 2 shims for each place your nailing or screwing.
Cut your own shims redneck and save yourself a trip.
I thought about splitting some 2x4 scraps down thin with the table saw. But aren't door shims tapered? I don't know how to do that on the table saw & still have ten fingers.
What bugs me is the threshold is freakin' plastic.
Looks sturdy though. If it's flat on the floor.
What AK said. You have to leave flex room or when it rains your never gonna open it.
You could cut an angled fence piece to use on the table saw. Or just rip you some with a circular saw.
Ok I got it,... I'll leave a half inch gap between the 2x4s & the door frame.
I'll stuff foam weatherstripping in the gap, it'll be like a spring trying to force the latch side inward against the door.
Screws installed from the door opening through the frame &weatherstripping & into the 2x4s will squeeze the weatherstripping & enable fine tuning of the gap between the strike plate and the door.
Maybe I'll even take a flat hole boring bit and countersink 1/8" into the frame so I can put flat 1/4" washers under the screw heads so it's flush on the surface.
Using screws longer than they need to be, like 3" #8 drywall screws, there will be enough thread depth they'll never wear out even if I adjust them twice a year.
I could even do something like that with the hinge side. The door frame can be firmly attached to the 2x4 but I can use weatherstripping & screws or lag bolts to secure the 2x4 to another one beside it so I can adjust the squareness of the entire door frame.
There's a bedroom door upstairs in the house that won't close all the way because after 100 years & at some point, raising the entire house 3 feet, the doorway is no longer square & although the hinges side is perfectly plumb, the door hits the frame at the top.
I'm just kinda worried cuz the wall I'm building is only going to be attached to the pallet rack by clamping. And I'm going to intentionally let it slip downward after the plywood is hung.
Use shims, not the weatherstripping! You will cuss that door forever if it's not anchored firmly. Use your Google fu, this is all online.
Valve springs with bolts through them. :D
C'mon I want as much redneckery as possible. It's bad enough I went with a store bought door.
I had a shed once. I made the door out of 2x4's & plywood on both sides. It was over 4" thick.
The latch was a bicycle wheel axle & bearings. I cut the hub in half to widen it & used a threaded rod instead of the axle. I welded a knob on the outside & a piece of flat stock to the inside. When closed, the flatstock would fall behind another piece of flatstock screwed to the 2x4 on the wall. Further inside was another piece of flatstock held out with washers & lag bolts so trying to force open the door wouldn't put any stress on the weld on the end of the threaded rod.
It worked perfectly for years until we moved. I greased those bearings when I assembled it, and when I welded the outer knob on, I used an arc welder to provide instant meltage & then I immediately cooled it with motor boiling water, then cold water, before the heat could cook the grease or burn the plywood.
I did the same thing on the east barn but it's not as flawlessly perfect as on that shed because the barn door is made of old planks & it's falling apart and sags & stuff.
I'm sort of beside myself here not believing you don't know how to hang a door! I'm also guessing you already took the shims off the door that it came with? Huge mistake. Go in the door section of Lowes or wherever and buy the shim pack. Make sure you pound them in so they are tight. Don't let the screw bow the frame because there's too much play.
