I bought a can of Rust-Oleum today.
I'm gonna paint mine before it looks like yours.
3 coats ended up using a full pint can. I got two pint cans. "gloss sunrise red". The other can was going to be for the side railing but I decided to go with silver because of the galvanized tubing I plan to use that won't hold paint anywhere except around the welds where the zinc will be sanded off.
Unless I decide to go break the bank buying square tube. I'd rather use square tube.
Tools of the trade..
They have wire wheels for the angle grinder. I tried one but as soon as it began to fray it started sparking on the inside of the shield.
Drill ones work better because you can reverse the drill on the tough spots. The bristles get bent over from the rotation so when you get a tough spot you can reverse it & the bristles attack it angled into the rotation instead of trailing.
Made straps out of flat stock to add extra beef.
Didn't like the eye bolts cuz I can't tighten the bolts very much before the flat washers start pressing into the plywood.
Little redneckery,... I welded the washers to the bottoms of little scraps of 3/16" steel. Now I can crank the eye bolts to 80,425 ft lbs without crushing the plywood, and the washers pressed into the wood gives it traction against side-slip.
Cargo attachment points are now rated for two million pounds, which exceeds the total payload capacity of the trailer by 1,998,750 lbs.
:thumbsup:
Not enough. Pull the rubber caps and fill the legs ;)
It's a 1" thick sheet of polystyrene, locked into place by Great Stuff.
I don't know if it'll float, to be honest, because I haven't weighed the chair & done the math.
Assuming it's 12"×12", it's bigger than that but whatever, it's one twelfth of a cubic foot, which would displace 64 lbs.
5.33333 lbs.
Probably close to ten pounds of flotation if there was a way to get the volume of the Great Stuff.
How much does a steel folding chair weigh? :dunno:
I can't fill the legs with the foam because it'll trap water in them. There are rivets where water can get in.
Can't fill the whole tubes past the rivets (using a long sprayer tube) because without exposure to air, that stuff will never dry.
Thinking I'm going to use thin wall square tube for the railing on the trailer instead of round tubing. Easier squaring & fitting.
Probably $20 a foot though. :mad:
The wiring on the airplane wing hauler trailer got chewed up by furry little creatures.
So I'm putting the new stuff in conduit. :sneaky:
Chew on THIS you furry little bastards. :thefinger:
Rodents won't chew on white wiring.
A pal told me that years ago while we were replacing a bunch of crap that had been destroyed by mice, but it also had a huge loom of all-white wiring which hadn't been touched.
Seems to be true in my experience.
FYI.
FYI.
That's weird.
But I'm not sure it's mice.
It was only chewed up right over the axle & up by the tongue that was resting on the ground.
Same critters chewed up a garden hose that was rolled up & tossed over the enclosed aircraft trailer's tongue and that also was only chewed up within a few inches of something to stand on.
Mice can climb all over things so for it to only be chewed up in select places makes me think it might've been teething juvenile rabbits or squirrels.
I'd be interested in seeing the other side, how they hooked up a chain drive to a barrel.
Sending this to the Geezer.
BTW he's currently outside adapting a hitch rack to fit his 3 wheel bicycle.
He presented the challenge to me and I told him exactly how I'd make it,.. Monday when we can get some 2" square tube and some angle iron.
Too impatient to wait, he's out there doing something with a severely warped scrap of plywood & a piece of 3" PVC.
:coocoo:
I've got the lights finished on the wing trailer but I can't test them with a vehicle cuz he's got pikes of junk in front of the workshop door.
I was going back my car up to it and test them. No intention of ever pulling it with the car but I know it's trailer light wiring is good cuz all the connections are inside the trunk, out of the weather.
Ok for the first time in the 25 years my dad has owned this wing trailer, it's actually street legal.
OK not "FOR REAL" legal, because that license plate is for a different trailer, but close enough because if a cop runs the tag it's registered to me as a "homemade trailer". ;)
And there ain't no damn license plate light but nobody notices that stuff.
Actually there is,... It's just 3 feet to the left of the plate. ;)
I upgraded the raft stereo.
Took the stereo out of the camper.
It sounded better in the camper. :mad:
Better than the little round speakers though. And it's got the USB thing so I don't have to screw around burning CD's.
That stereo sounded HORRIBLE when I first tested it with the bottom of the box still off.
Then the sound got way better after I put it back on.
Probably sound even better if the bottom didn't have holes in it.
Problem is I had to put a 4" computer case fan and then enough 1" holes at the other end to equal the surface area of the 4" hole so the fan can cool the amplifier.
If I had it to do over again I'd have the amp and speakers in separate compartments so I can ventilate the amp part while keeping the speaker area sealed.
