The same time the Geezer put that trailer wheel on, he put the mower wheel back on. It had a slow leak so he took them both in at the same time.
Same damn thing happened. :mad:
All but one stud is loose and threads are trashed.
The loose studs fall into the brake mechanism & jerk the mower to a stop.
There ain't no getting that brake drum off to replace the studs.
I even ran my impact on the puller, putting a mind boggling amount of pressure on the puller & it didn't even budge. There's nothing holding it on to the axle so there's no reason it shouldn't come off. I beat on it with a hammer, put the air hammer on the end of the puller, brake drum, of course tried penetrating oil, didn't budge one micron.
So I said f*** it & sent the Geezer out for new lug nuts and a large quantity of half inch washers.
I'm just going to put the wheel back on & run two lug nuts on with SuperUltraMegaGodzilla torque past those f***ed up threads til they seat cuz they're also lug-centric, then use washers on the others just to hold the studs out so they don't hit the brake stuff inside that no human eyes will ever see...
It's either that or replace the perfectly good & probably ridiculously expensive hydraulic motor, hub, brakes, drum and mounting bracket. Cuz that brake drum is NOT coming off.
:gun3:
And the lesson boys and girls is keep Geezer away from tire changing. As smart as @Duck says he is I believe this to be a ruse to get out of future labor. Kinda like the time my wife asked me to do laundry.
"Whatcha mean sorting clothes???"
"Nah those bras didn't have straps when I put them in the dryer"
"Wool does not shrink! How the hell do sheep stay outside then??"
Problem solved;)
Problem solved;)
No if you knew my dad you'd know he would NEVER do anything that would result in him having to spend money. ;)
He won't even spend money on basic maintenance on his vehicles except occasional oil changes.
I bet I could pull the air filter out of his S-10 & set it outside on the concrete & weeds will start growing out of it.
"Air filter? What's wrong with the old one? Just blow it out with the compressor".
Geezer is back sooner than I expected...
I bet he forgot the washers,... Or forgot to bring one of the lug nuts with him...
I did consider removing the entire hydraulic motor, bracket, brake and hub assembly and putting it in the 20 ton press, with something behind the rim of the brake drum but I didn't because I'd have to open the hydraulic lines and make a mess & it's Sunday after 5 so Farm and Fleet was closed and I couldn't get hydraulic oil to top it off.
And I was too lazy and was in the middle of changing the headlight on the truck. :toothpick:
After finishing the truck I went & got Crazy Rita's mower & fixed it's steering.
There's a bushing that locates the bottom end of the steering shaft where the gear rides in that semi-circular gear rack thing. It was held in place with a snap ring that had come off. Had to take half the mower apart to get to it. :mad:
Before testing it, I checked the oil and it was bone dry. :confused:
Anyway steering works good so I brought it back.
Figured out its easier to uncouple the trailer than pull the stupid pins out to work the tilt bed on my little trailer. Especially when I forgot to bring a hammer. :mad:
Then I got to hang out with Crazy Rita's even crazier sister and her flaming gay son while the news of the terrorist attack at the gay bar in Orlando was on the TV. o_O
That was ... entertaining... If that's the right word for it... He was crying like a little girl and saying stupid stuff, and I had to pretend I have no political opinions at all, while wearing a shirt with an AR-15 graphic on it. :rolleyes:
One of your lighter days.:couch::biggrin-2:
The Geezer just called me.
1:30 AM.
"When we were working on the ZTR I meant to charge my cell phone. I put the charger in my pocket and now I can't find it... Oh I forgot to check my other pocket..." -click-
:rolleyes:
My pal, Herman [cab-mender extraordinaire] offered either of these beds to me for free today.
Working lift with pump, motor and everything except battery.
I told him I might have him hack the front off one [so I wouldn't have to stretch the frame] and mount it on my old '94 WGMC.
He said, "Well now THAT will cost you!"
:cool:
He knows I have a weakness for free stuff.
0wpzLvXAnmoHBtdzCqF4ZBUbCdEpfBUru8m4LPzjZPhB11r_mrEiMgJkk2cYuWeLOLTuOsUckuU7s00BrXFiy1nJgfSNQc_WCwIPGEInCwhbgpegGSfZugz3_rPAWQOyLnI_UdSWceQhyV9nIJXI4SclaSz0MlKfv8LM_lKUN1-HB46U0KJvcjspEeeWysnbUz7ufW-galXT12n0HLiREXv-8Fcc-OOWstXqN04aFFPvr1G8DZvYV8ggm8gwE_SbeUuVEB3TRBmsSKRF2xdT-JqYv6w7Dm2ZjiStFOYgCg9PagOdHutpvH9kevVI5aR7nmdgy70F7qCVos_Yo8oqTB-ppewRGP6SYDstoHkG8rflEjeppM5l0fOptR5_xu5F5Qs9OL7TK6P5WO4uQOXCOfjv-THnktWMEuVvQVeI7-xR5-28qR9ZDhFj67ZF-BkgS9IkXq3mymUAC-y6G1H0cGzXaT5pnC_lQwe_kPCathuozug0qMBNwpFsBdMlVSYBkoQt-VlwB3QgCOgdAQVzMAylBXb8knlFzqaL1vFkEaDyAB4jGM6FfzvxPljQioDh5xnYo1MxzFcVF0fO1z55nwFIXp23VFM=w1186-h667-no
