for the past few cars, or pick up trucks, i'd buy the K&N air filter. then i'd remove it, wash it, dry it, then re-oil it, reinstall. good for a million miles of service, they claim. saved me money, as the cost of a good air filter at autozone or some other parts stores, averaged about $25 each. in short time, the K&N air filter paid itself.My days of working on cars ended when everything became a sensor. The only thing I do on my own now is change the air filter.
I will be damned if I am going to pay the parts mark up and labor on that![]()
He's probably got a filter on it. Or traps at every outlet with a bleed valve.My mechanics shop has been running black pipe for at least 50 years. I should tell him he could have problems in the future.
Good air dryer then.No bleed valves, no draining, no nothing. Filter at the compressor outlet, that's it. Pretty much every garage I've ever been in is the same.
From the memory banks of my days an instrument tech: There are two filters on any decent air system, one is for water, the other for oil. On our setups, because rig air tended to be wet, we'd run thru a Facet water filter right at the tap, plus we had Parker-Hannifin oil and water filters that were mounted on the remote air supply tanks near our systems. (We used Foxboro CP transmitters, and they had to have very clean, very dry air.) You do something similar and you can use any piping that meets the pressure requirements without worry about scale.Good air dryer then.
Nothing to hoist it from unless I take apart the drop ceiling to access a rafter.the way you have it cradled in the dolly, you could just use the come-along to lift it up there.
