@Duck s tank is 500 gallons.
40% = 200 gallons.
According to Google current price in Illinois is 1.65 So that's $330 since he checked it at 40%.
In Missouri I paid 1.04 in the fall and topped off a week or two ago at 1.36....
I got the LPG price for Duck in Illinois from eia.gov
I just checked Missouri and it says 1.60 so Duck may be paying less than I estimated...
I naturally assumed that the price in Illinois would be higher due to taxes out the ass.
$1.48 at the time they hooked up the garden hose.
But assuming your number of $330, that's heating the house 24/7 too. It's also fueling the oven/stove.
The only reason the shop had a been heated to a comfortable temperature for ten hours a day and idled at night is because I've been in there every day working on it. We don't plan on heating it all the time once it's done.
Also gotta keep in mind that in the beginning of that time period, the majority of the walls were nothing but sheet metal and that heater was running almost continuously to hold a temp. During that period I (gradually) insulated all but an 8x8 section with R-19 insulation. Now it cycles on and off, spending the majority of its time off.
No it's $1.699999999997 according to the receipt.
Yes that many 9's. :coocoo:
It cost $1500-2000 to heat just the house each winter before I fixed a leaky basement window, shrink wrapped the downstairs windows, isolated an unused bedroom (by turning its radiator valve off and keeping the door closed) and the boiler was replaced with a modern hyper-efficient model. And replaced the broken glass in the front door with painted plywood painted to match the door.. :rolleyes:
We're about halfway through the winter at $340 so far, with the shop added. Probably $400-500 because it was cold for about a month before the shop was hooked up and I noted 40%. So... That's pretty damn good.
Also considering I totally screwed up estimating how much of that R-30 insulation I needed for the ceiling and plan on putting the large quantity of extra stuff in the attic of the house, which only has about 4" of fluffy in it.
Well the furnace drain is done.
That's all I got done.. In like 45 minutes. Had to go fetch another medically orphaned truck in the Chic-ghetto and bring it home today to keep it from getting stripped to the frame. They're sending someone to get it tomorrow. That took all freakin' day. And those rat bastards woke me up at the crack of 9:AM so I only got like a 2 hour nap. :mad:
How did you do that with no license to drive?
Ya see, that's where it gets... funny....
I renewed that crap in December.
But I never sent them the copies cuz I was kinda hoping they'd fire me. o_O
So I had to waste a ton of time at the library sending faxes. :mad:
That's an 8 foot ground rod.
Can't find my sledge hammer, and my kinetic persuasion device for wall studs isn't heavy enough. So I pounded it 7 feet into the rocky, frozen ground with this:
Thinking I need to remove this now? This ties the ground to the common. But I just grounded the panel to the earth.
I added up all the receipts because the rebate deadline is approaching.
So far, the plywood, insulation, drop ceiling stuff, framing lumber, electrical stuff, heater and it's exhaust and fireproof wall steel, gas regulator, and some tools like the miter saw, plexiglass for that light box thing,.... Before the rebates,...
$4300. :stare1:
And my dad was expecting it to be twice that much. o_O
It depends on how power is fed to that panel, @Duck. If it's coming off another breaker panel, there's no need to bond to ground, as it should be done in the other panel. The bonding should only be done in one panel, or you're setting up multiple paths if you have wiring issues, and can end up with a hot where you shouldn't.
It's fed by a big tandem breaker in the house.
Only two hots and a neutral coming in from the house.
No idea if it's bonded in the house.
I just want a local earth ground out here. When that push-in wire nut thing was leaking to the outlet box, I'd have preferred it pop a breaker immediately rather than work just fine, but electrify all the conduit in the building.
It's still a mystery how a hot shorting to the conduit, which is grounded to the panel that was bonded to neutral, wouldn't pop the breaker, and still be able to run my drill press. :dunno:
It's all earth grounded in here now.
I also grounded the entire pallet rack.
Star washers under these bolts. That's the only purpose for bolting the horizontal beams,.. Simply making an electrical ground path through the whole thing.
I fucked up and bent this conduit wrong and there's a one inch gap between it and the ceiling.
I purposely bent this conduit to create a gap between it and the ceiling so after I secure it properly it can do double duty as a rod to hang my ratchet straps from. :cool:
:thumbsup:
It don't matter...
The next time lightning strikes that mess, th' leakin' propane will explode.
He's gonna croak.
:eek:
