I was just doing 70 in a 65 on I-80 east of Joliet. A can hauler passed me like I was standing still. He had an empty chassis.
Just for the hell of it I stepped on it a little, caught up and paced him at 86 mph. I believe the truck speed limit there is 60.
About a minute after I backed out of it, he hit a minor bump, a bridge transition, and his chassis got airborne about a foot. Higher on the left side. He didn't bother slowing down either.
:coocoo:
i have a toro snow blower, (2 stage, 4 stroke engine) bought it back in march 1994, (that's the down payment/order date) but i took delivery on it in or about Sept/oct. cost back then (with an electric start, $895.
still has the original tires, but it was made here in America.
i check the air pressure in the beginning of the winter season, still holds air...
:coocoo:
then if he had tipped over, you would have made a great witness......i know i woulda
Geez, @Duck . You could put one of these up there!
ELECTRA SAVER 350–500 HP ROTARY SCREW COMPRESSOR
http://www.gardnerdenver.com/workarea/downloadasset.aspx?id=10516
Oh, and I'm about to add another wall stud to the corner cuz there's nothing to screw the interior wall plywood to.
It's going up where I'm holding this scrap piece. And I'm using Liquid Nails. Because why not make it strong enough to crash into with a 3000 lb tractor that has no brakes?
Cuz ya know,... there's a 3000 lb tractor with no brakes in here.
And a beer fridge. :D
If you fill the tank on your compressor halfway up with water it won't be top heavy.
You're welcome.
I just realized I could put that 350 gallon water tank up there and have a sink for washing my hands.
So I grabbed the tape measure and it's too tall. :mad:
By about two feet. :mad: :mad:
Oh well. Air compressor it is.
I could put the compressor inside the electrical fortress and not have to listen to it. But the pump would be running cold all the time in the winter and not have much ventilation for cooling in the summer. That's the only reason it's going up on top.
That and the challenge of figuring out how on God's green earth I'm going to get it up there is fun. :)
Next time a tornado rips trough, the entire barn will be toothpicks.
Except the electrical locker.
I dunno. The studs are 2x6 every 2 feet but doubled up in the middle of the 10 foot sections.
And those 6x6 posts are set 6 feet down and surrounded in concrete.
Somehow I gotta run a 2x6 joist right through that diagonal steel brace without cutting it.
It doesn't need to be strong but has to be a 2x6 and centered on 24" for the insulation. Nothing is going to be on top of that part except dust because it's under a pallet rack shelf.
But I gotta make it strong anyway because that's how I roll. It's against my religion to build stuff that ain't strong.
"Thou shalt not build flimsy crap".
Take some 1/4" plate, bend it so you can bolt it to the brace and have enough of it vertical to bolt thru the stud. Cut the end of the stud to match the angle of the brace. You slide all that together and bolt it up, it'll be strong as hell.
For some odd reason, I though. studs had to be 16" oc.
On load-bearing walls, they do.
16 on center if load bearing 2x4's are supporting the 2nd floor of a house. Doubled up 2x4's are for supporting door and window headers.
My door is only 30" wide and has double 2x6's for the header. So that's 4 2x4's for 30 inches of wall. Equal to 7-1/2" spacing. Then a 22" span and three studs in the corner with one of those perpendicular to the others. Turn the corner and the next stud is 14" away. Then 22" to the one that's attached to the post. Above that 22" span is a 2x4 top plate and a 2x6 header.
The odd spacing on the short wall and the part of the long wall under the pallet rack is because the insulation I'm using is 23" wide and I hate cutting that stuff.
Altogether, 1/2 of the weight of the air compressor will be supported by 8 studs over 8' 4" of wall. So like 12" spacing.
The other half is supported by the three 2x6's on the post wall. One on top of the other, glued, also lapped on the back by steel plates effectively making it a 2x12. And the bottom one is doubled in width by the third 2x6, also glued.
I couldn't give two shits about the part of the wall that's under the pallet rack and simply spaced it for 23" wide insulation.
This single 2x6 joist, bolted to the pallet rack leg, terminates the load bearing section.
Framing done. Gotta relocate the light switches and the 240 outlet for the air compressor now.
Or tomorrow.
This is what I did.
Once I actually measured it, it only required a little notch.
Still plenty strong enough to hold a layer of dust. ;)
