Ended up limping that blowout back to the yard and grabbing today's delivery to give me basically a 3 day weekend.
I dont trust this company to get a reimbursement that wasnt preauthorized so I refuse to buy a tire even though I'm capable. I can usually get that from the regular local office dispatch but after hours corporate is offshore. They don't even know the difference between a truck and a trailer.
And my last road service experience coordinated by the company was so bad as in they never showed up, that I don't even try to do that.
I figure I'm pretty much on my own after hours so I do what I gotta.
My front collision avoidance radar reads out the speed of the vehicle in front of me until it's out of range.
That's gotta be cool. It'll train your brain to accurately guess how fast someone passing you is going. So like, you'll be pretty accurate when gauging the speed of a passing vehicle when you're driving something else.
I wonder if a flying potato is too small to be detected by a cop type of handheld radar gun. 🤔
Because then I can measure muzzle velocities and bug the shit out of @GAnthony to help me figure out the largest explosion a potato can handle without splitting apart in midair right outside the muzzle.
I don't want to launch mashed potatoes across the neighbor's corn field because it won't go very far.
Once I get that part figured out, I can work on making a hand cranked gatling that shoots like 4 'taters per second (TPS) which I expect will enable me to go up on the electric man-lift and seed like a 50' x50' ammunition garden in like ten seconds. So I'll have exponentially more ammunition next year.
And homemade steak fries. 😋
You lost and won me at steak fries.
i would imagine anything higher than a .22 will split a potato
yup, either a .17, or a .22
A small caliber bullet (such as a .17. caliber or .22 caliber) will usually punch a clean, small hole through a potato rather than splitting it completely in half.
  • Why it works: Smaller, high-speed projectiles pass through soft, dense, and watery vegetables like potatoes via hydraulic displacement, creating a clean entry and exit wound without generating enough blunt force trauma to fracture the entire mass.
    • The exception: If the potato is small or if a larger caliber bullet (like a 9mm or .45 ACP) hits it, the massive transfer of energy and expanding temporary cavity will cause the potato to violently explode or split apart.
I tried to crank it but the legs were in a bind. So that wasnt happening. I chased down an SAE @Rigjockey and he happily lifted it so I could crank the legs up to match my 5th wheel.
After all that I got hooked up and...no lights on the chassis. None. No clearance no blinkers nothing.
Checked my truck fuses because I've come across some that some idiot was shoving a wire into the 7way and it shorted me. Nope my fuses are good.
Hooked to another across the aisle just to confirm and it worked fine. Definitely not my truck.
So I had to lose that revenue for the day.
Other than that and a brake checker (sortof) the day was relatively uneventful which is always good.
Oh and I fueled at the TA in Ashland VA because my plans to fuel at my usual was kaboshed due to these no lights shenanigans. It felt like forever waiting for someone to fuel and pull away. I haven't had to experience that in years. 😂
Spray them with oil, and put onion powder & garlic salt on them.
Flip & repeat.
Stick em in the air fryer for 15-20 minutes, depending on how thick you slice them.
I forgot what temperature. 😱
That's too much work when dollar general has frozen bags. They rearranged my local to almost compete with Aldi. Its wild and fun.
I am always happy to help out a driver with a high trailer.
Well, at least the trailer is lowered for the next guy once it's fixed.
You've got me thinking now. When I worked at the towing company and I hauled customer loads on their trailers they were more often than not dropped way too low. I had various blocks of wood in my headache rack for just such an emergency.
When I would go help the wrecker guys by taking the trailers it was ideal if I could get there before the trailer was unhooked. The vast majority were the cheap fleet trucks that didn't have a dump valve and were really low.
If I wasn't the one dropping the trailer cranking the legs as hard into the ground as I could; it was almost guaranteed I would have to get the blocks out and frig around to get under it. Then again maybe I was the asshole. 🤔
I have drivers give me shit because "I dropped their trailer too high". I can assure you, I do not touch landing gear.
Yeah the entire purpose of the lift is so you don't have to.
CSX has an entire row where every spot is sunken by 3-4 inches where the legs end up. Having a high one isn't rare. I just haven't seen one THAT high before.
Much to my surprise they're Goodyears. Usually you get whatever variant of Linglong Dingdong on a rusty wheel. Not saying these are top line GY but still (I don't know anything about them).
They even brought out the torque wrench. 👍
