A friend of mine replaced his heat shield on the step. It was like $300 and that was a painted one not chrome.
You are already ahead of the game.
Fortunately they're only $200 for the painted ones now but mine isn't mangled or anything so it's kind of wasteful to spend that much coin.
Plus I might have it traded before the thing would even arrive. 😀
An addendum to this post.
If I'm buying another heat shield, I want it to be a shiny stainless steel one. Not spending 200 bucks for plain black. I'd rather spend $400+ for fancy. I see them going down the road and they look pretty good.
I'd also look into getting mine chromed before buying a stainless one. There's a playing shop not far from here, I could drive it up and ask and get a comparison quote.
Suuuuuuuuper low priority though.
I'll go out there and say that you could buy a brand new, wrapped in plastic S/S shield, at about 1/4 of what a plater would charge you to do yours.
$400 for used ones. Haven't found new yet. Not sure what the part number is. Don't feel like calling a dealer since it isn't important enough.
Far from perfect. Not sure how the paint will hold up since I scratched some reinstalling it. But it's better than it was. The scratches are mostly hidden under the steps.
Hoping it just needs more cure time. I used farm/implement paint so it should be okay for at least a little while.
I located an aftermarket new stainless shield for $475. It doesn't have vent holes but it's the same fit as mine with the extra up top.
Most of the 2016+ stainless don't have the bend above the steps. I'm not even sure at this point if my model year had a stainless option.
I don't know if a plater would charge 1600+ for that shield but I'd probably just get that aftermarket one anyway. It would be faster and an immediate bolt on.
Don't know if I mentioned it before but also part of this barrage of tedium, I removed the grille and glued one of the mounting tabs that had broken as well as the MACK emblem that was rattling.
I can spend $800 for a new OEM grill with the emblem but I figured 20 minutes and 13 cents worth of hot glue is probably more prudent for the time being. I did that on Saturday and it seems to still be holding.
Walking around the truck idling today and there are significantly fewer rattles. I don't like rattles. I have one more big one and that's the battery cover brackets. The battery cover doubles as the driver side steps and the previous driver was a hoss and bent the brackets out of shape, so the cover has too much free play. I tried squeezing them in my vise before but was unsuccessful. I need to get new brackets or a press or oxy/acetylene torch to heat them up.
Unless I can simulate a press with a bottle jack, a 4x4, and the truck itself.
Ran my bread and butter Upper Marlboro at 62mph and really didn't lose any time. Maybe half an hour. And got significantly better fuel mileage.
I'll do more now that I know hauling ass and wasting fuel was pointless.
I left the house at 6am and was back at the house at about 3:30pm after looking at two cars and talking to a mechanic down the street via the owners wife(?) via translator.
I'm basically at the point where I'm most likely going to have to farm out the power steering hose on the wagon. I just don't see myself fenangling it. The market value of the car itself isn't worth paying someone to work on it but compared to what's on the market as a replacement it's a helluva lot cheaper.
I can do the alternator that the leaking hose took out myself. It's an upper standing job.
My ultimate goal is a brand new F250/F350 cash but I may have to stop short big time and finance something like a Hyundai Santa Cruz (that 4 door El Camino thing) because I have so many setbacks it's insane.
The beater with a heater won't last forever.
I wanted to be down to just the old pickup but the ignition recently failed so I need to take the dash apart and fix that. It's a total no start without super careful finesse of the key position. The lock cylinder is NOS replaced not long ago so I know it's deeper. Figuring ignition switch, and have one on order to replace.
Anyway the point is you can only get along with old stuff for so long before you need to move on and put it back as toys rather than grocery, parts, and mail fetcher. Without PC my Mack is no longer the backup plan it once was.
Where’d ya go in Upper Marlboro?
I won't say in case you want to rob me but it's off 301.
It was also my first ever run at Schneider after the lockdown started. They're a big customer so it's a consistent gig.
Interestingly (probably only to me) I noticed in a detour that it's not far from the place where I ordered my F250 steering wheel.
Still runnin for Amazon?
Didnt know they had a place over there
I try to avoid gettin that close to Washington. Gives me the shivers
