It's janky but I wrapped aluminum foil around the hose to hopefully redirect the leak down below and away from the alternator. If it works, I might not even bother having it fixed and just keep topping off. The important thing is the alternator, IMHO. The leak isn't a push everything out immediately kind of leak. It's seeping out of the crimps over time.
I don't see myself having this car THAT much longer, and today's shop rates aren't cheap. If I can get 6 months or so out of it that'll let me keep hammering away a sizeable down payment and simply join the 2020s with something new.
The car has its virtues but it also has plenty of other potentially terminal issues that I absolutely will not spend the money to fix or have fixed.
Who knows maybe ultimately I'll get a wild hair in the cooler fall one day and go out and find myself doing the hoses.
I can do them if I move enough crap out of the way. It's just ehhhhh.
Also if the old truck only needs the switch as I suspect, it'll basically be dead ass reliable again, further pushing out the need for any other vehicle.
I get annoyed when everything goes down at once and start looking at new cars. I looked at used ones too and came up wanting. Everything cheap is a worse mess than what I already have and everything nice is almost as expensive as new. And the middle of the road stuff is a big question mark.
The whole point of the next buy is to not have to sink wrench time and parts money into it. I already have vehicles like that.
Went for a joy ride battery charging technical exercise a bit ago and didn't realize how much I missed this cheap POS.
I put about 50 miles on it just tooling around some back roads.
About an hour or two ago a 17 year old female rolled her car with a 14 year old female passenger and another female teen (don't remember the age plus the EMT was confusing) passenger. They're all fine, just bumps and bruises.
All I could think was "yeah but are they cute?"
So I'm definitely a night owl by default. Snoozed all day and woke up at 8:30pm all bright eyed and bushy tailed. Watched the rest of the Chicago Cup race and now it's almost midnight and I'm hooked up to the Mack trying to figure out ABS faults.
It's basically down until I fix it. Mostly for DOT reasons since ABS doesn't even play unless you panic stop. But it'd be my ass if I was in UM and killed someone who jumped in front of me and brake checked and my ABS was knowingly faulty.
I have the Bendix Acom software so it's at least pointing me in the right direction. I mostly need to decide whether I should pull the wheel and prod this thing myself or pull the fuckit card and let a shop do the labor.
I miss my Ford. Except the loud cabin, no Jakes, manual, non-working heat and AC, oil leaks, shit fuel economy. If I can fix 3 of 5 and my authority is up, the Mack is gone. IJS.
Looks like a wheel speed sensor gap issue. Hopefully it's not more than that.
Since I'm out here I'm doing a parked Regen and sublimation because why the hell not. Soot level in the DPF is only showing 31% which means the Regen is pointless but I don't know how to see the soot level without doing a Regen. It's not a menu option on the truck for this model year (or it was fleet deprogrammed) and I don't see it before starting the process in PTT.
It only wastes a couple gallons of fuel anyway so if it prevents a parked or passive (debate) I'm all for it.
Soot isn't moving below 31% so I'm theorizing that it's probably packed pretty solid and passive regens have been doing their job.
31 is nowhere near a problem so this DPF probably won't need a manual cleaning for quite sometime.
I had it done once about 200k ago. Puts me at about 1m on the mileage for another cleaning or replacement if my in head math is correct.
To add. I did not have the software so I don't know what percentage the cleaning actually got me. If it was still 10% or whatever after the cleaning I'm good beyond a million.
I don't know for sure that the DPF cleaning actually got me to 0%
I usually walk away from the Regen knowing it's going to take an hour. So I never watched the soot level before (or I did but have dementia).
It read 31% until the Regen completed then immediately dropped to 16%.
Looks like the software doesn't track it in real time.
On the plus side, 16% means I'm even further from needing a cleaning/replacement of the DPF.
We used to get regen warning on our Volvos, Mack is the same thing.
I wish I could remember how we fixed it. I know we would do a parked regen until the soot level wouldn't drop any further.
I do remember the other driver would say the soot level as the suit level:foreheadslap:
