Still...$20+ each. That'll eat at the bottom line. Why waste them? There is a few ounces, if that, of crud on the bottom of the tank. Run it. Isn't that the intended purpose of filters to start with?
FYI Biocide is supposed to kill it and prevent growth. So that it doesn't become more than the "few ounces, if that."
I'm a big fan of nipping things in the bud before they become a bigger problem.
Not sure why I procrasturbate the way I do, but I finally took my DPF shield, steps, and bracket off to clean them up and repaint.
There's more stuff I could take off to refurbish but it's a real rabbit hole of where do you stop. I'm not about to frame off restore this thing while it's in my driveway. Being in Pennsylvania the surface rust goes deep. 😏
it's sorta like a house.
many times things are repaired, replaced or, rebuilt, that are never seen, but must get done, to keep the integrity of it all.
trucks as you know, get surface rust where you cannot see it, but ignore it, and it'll get deeper.
many products can be found to spray onto a cleaned rusted surface, to stop the rust from spreading.
how good they work, i don't know
it can be tough, but a power washing every so often in the winter, to get rid of the road salts/sands as soon as possible.
From a man-hours perspective if I go THAT deep I might as well replace it all rather than R&R it.
These emissions trucks aren't lifers anyway. I'll be happy if I get 2 more years out of it.
In a perfect world I can sell or trade this Mack before it needs a clutch, brakes, and/or tires and have a newer (2020+) sleeper and the LTL fixed up and useable or sold.
There's a 2020 Mack sleeper at my local dealer for 45k with under 500k and a Tripac APU so I might run mine down and see how much they'd give me for it on trade. I don't need it looking like a jalopy.
I'm making it look pretty for myself first and foremost though. Kind of a pride of ownership thing but with limits because it can be unending.
I've stepped through the bottom part of my lounge pants legs. My sister got them for me for Christmas probably 5 or more years ago.
So I put her on the warpath to get me some new ones for Christmas. I'll know if she loves me 6 months from now.
These pants are cotton and wicked comfortable. I don't know if she knew what she was in for at the time. But I wore them all day today working on my truck.
Judge me as you will but it's freedom.
90 degrees is hot. Went out and sanded down the heat shield and primered it again.
It's filler primer so I'll have to sand it down once it dries enough before I can paint. I got some sanding disks that go up to 2000 grit so I won't have to worry about ripping through the primer, and won't have to sit there and muscle it by hand either. I just need to get the chiggers off that this kind of primer leaves behind.
I got some wide spray can nozzles to emulate a real paint gun a little better. Hopefully that'll give me the results I want.
Got a couple coats of paint on the heat shield. Looks a LOT better than the hot mess it was yesterday. Still not quite what I'd like but considering my conditions (non-sterile environment) I think it'll be okay.
Brackets are on with the new shiny hardware.
Once it's all put together it should look fine.
A friend of mine replaced his heat shield on the step. It was like $300 and that was a painted one not chrome.
You are already ahead of the game.
