I never thought of that being the reasoning for such high oil temps. :headscratch2:
Because the classics sit so much, when they do go out, it's for at least a few hours to get them hot and burn out any moisture in the lubricants. They have no gauges for such things. The old world Cadillac owners were happy when just an idiot light came on signalling a catastrophic failure.
I even use Delvac 15W-40 in them with a quart of Lucas. The Delvac has the Zinc, the lifters need to not wipe out the cam. People can say what they want about Lucas products, but they have been a Godsend for me in the old cars. They run quieter, cooler, shift smoother and stops little pump noises from the front trans pumps and P/S pumps.
Yep the high oil temps are to boil moisture off. Since water boils at 212, the 220-240 gets rid of it relatively quickly and keeps it away.
Ran last night again. Love hate relationship with night driving. It's all good until the idiots with illegal/poorly aimed headlights come out and fill both the roads and your mirrors.
On a more positive note, I took notice that the passenger side clearance light on my mirror was growing increasingly dim. That's sort of the positive part. In daylight I wouldn't really have been able to note the discrepancy.
Anyway, got home this morning and put LEDs in both sides and noticed the dimness was actually from the wires flopping around. The sockets are cheap Chinesium so apparently they weren't solid enough to handle it, at least on that side. I secured the wires with some 3m tape and it seemed to fix it up. I can tug and push on the wires going into the unit and nothing happens.
They're also bright as f*ck now. I don't believe there are any halogens on the truck anymore, although the rear tag light might be. Everything else I have replaced either with the OEM because it was already LED or an LED equivalent. Even the roof lenses are new (to me and the truck) because they were crusty.
Yeah, picked it July 17, 2016, as a new '17 model year. It had 1200 miles on it. That was from Denton TX., to Greensboro, N.C. Now it's at 395,000. Still strong, no smoke, no oil usage.
I just ran the numbers and I get 56,400/yr. It sat for the better part of 7 months after it was wrecked. Couldn't get a hood and just about everything forward of the firewall was replaced except the engine. Some dumb bitch turned right in front of me when the truck wasn't even a year old. I, T-boned her F-150 at 45mph. I thought that she was dead. The airbag curtains saved her dumb ass.
The newest truck I ever drove was a 2015 Peterbilt 579 with I think 60 miles. It must have been run around Denton for some tests then towed to Pennsylvania.
I hated that truck. 😂
Other than my Ford, the oldest truck I ever drove was a 2011 Cascadia day cab at Schneider. It was a manual and had zero nannies on it, and best I could figure it wasn't governed either. Usual practice was to set the cruise and keep pressing the + over and over because it would max at 60 no matter what. Well...I was running down US 15 in PA and it didn't stop increasing. I think 72mph is about where I backed it down. Speed limits were 55.
Apparently that thing was too old to talk to corporate/safety as well. The newer trucks would rat you out for 68 on a downhill.
That truck was also hella smooth at 72. Far more solid than my Mack at the same speeds.
I got a brand new Pete 2016 in 2015 out of Denton. My truck was the only one that had and owners' addition hat in it. I still have it wrapped in plastic that's a186,000 dollar hat.
I also, a few times did a pick-up right next door to the Peterbilt Denton TX, plant. I think the place was called Terra-Pak and they made rolls of what makes juice boxes.
I needed mirrors anyway so I got heated and lighted ones. They weren't super expensive. The originals were high dollar tear drop ones and I noped out of that expense. The glass was sandblasted from the quarry so bad I couldn't use them.
I had first replaced the Ford ones when one of them broke. Identical mirrors.
The glass on them is fantastically clear and crisp. My experience with the Cascadias, even brand new, wasn't as good as these.
Had an SCR inefficiency code pop up. That basically means from the def doser back. After the def doser all there is, is the SCR. My SCR is brand new so it can't be that. So, def doser. Also had a feeling it was the doser because it was crusty around the mounting hole and my voltage was a few tenths down. That told me resistance aka plugged injector ports.
I had ordered a new one. It came today. I figured I'd just replace it. Well, it's defective at the coolant ports. It wouldn't stop leaking. It uses hot coolant to keep the def from freezing.
I ended up steam cleaning the original one and put it back on. No coolant leaks.
Engine code/light immediately went away as soon as I fired the truck up and my standing voltage at idle with only the ELD, tablet, and dashcam drawing is 14.0 again.
Now I just need to convince the ebay seller I bought it from to take it back. It's an OEM so it should have worked. But with it dripping coolant constantly it's an immediate no-go.
It's an OEM that I got on eBay. It came in original Cummins (Mack, Cummins, and others use this same part from Bosch) packaging and the seller is going to accept the return. So at least I'm not screwed there.
I'll see how long the cleaning lasts. I might just make it a maintenance routine as long as it keeps working. The effort is about the same and it saves a few hundred bucks.
what's that huge building behind your house?
i don't recall that being there when you first bought the place, and posted pictures.
New warehouse going in, but don't know what for yet.
the way Amazon is building all over the place, maybe a d/c center.
we have a large one here, to be completed before christmas i believe.
Could be. They already have 6 within 30 miles. Another wouldn't hurt. Then again Walmart put it one 15 miles up the road and 5 miles down the road. Could be another one of those too. 😂
I'm in a pretty hot freight lane so it could be anything. Thermofisher, Staples, Food Lion, etc they all have warehouses near me. Literally hundreds.
If I had a sleeper and a trailer I probably wouldn't have ever had to give up my authority. Look at @Mike. He's been playing in my sandbox for a little while lately.
