The more gauges there are, the more I like it. I have an addition 6 gauges on my radio screen should I chose that option. Nothing worth looking at though. Three of them are clones of the dash gauges. What's the point?
Amen to that.
I've had a couple trucks where two dash panels were just plastered with gauges and switches. One time my wife came with me and asked, "You know what all those are for?". I guess she must have thought I was an airline pilot or something when I explained every one of them 🤣
I have 3 or 4 gauge blanks and it bothers me. Pretty good set otherwise.
I have my rocker switch locations generally memorized but I still sometimes hit the traction control when I meant to set the cruise. IOW a glance is all I need moreso to confirm my pointer finger aim than a search for the right one.
I got the wipers nailed down right away though. It's the only toggle on the whole dash. 😂
Starting to think Mack has their own sizing on these coolant ports just to force you to buy from them. The OEM Bosch leaks too and they're centered.
Back to the original, except I put the new injector in my housing.
Having said that, the new code was for a def air purge valve. Circuit open which means it's not working properly. I don't know where that valve is yet but it was the only recent code. I cleared everything and my light went off and hasn't come back after a few key/ignition cycles. Obviously it was purging or attempting to purge the air ingress from when I had it all apart the first time.
In other news, I found where you can not only do a forced Regen in PTT but you can also do a def crystal cleaning. It's like a regen only hotter to clear the SCR and doser and such.
ALSO there's a doser test function here too, but you have to remove it and I already put the truck back together. I noticed that when I unplugged the doser and started the truck it threatened a derate in 60 minutes or less. I had steam cleaned the exhaust and was attempting to blow some out the little hole without disassembling the whole thing. That was before discovering the SCR crystal purge function.
So basically I'm thinking I'll keep my laptop with me and when I'm in the open somewhere, spend an hour or two purging this stuff.
I found that air purge valve. It's just out of reach of my little arms. I'll have to have a shop do that one.
The strange thing about it is when I rescan for DTCs, it first came up on 8/3/23 aka yesterday at about 12:30pm.
I cleared everything, it didn't come back. Then a little later it came back as active but last set on 7/31/23.
It's strange and I'm going to ignore it for now. It's not the code I was getting when I cleaned the doser the first time around. It's probably something activated when I had everything apart for cleaning, but oddly it didn't trip until 2 and a half days after cleaning.
So I dunno yet whether it's a real thing. Maybe doing a Regen/SCR clean will fix it.
In conclusion, I took the side of my truck apart for nothing.
Although, I replaced all the hardware so there are fresh nuts and bolts holding everything except the fender bracket. One more step away from Mack's nut one size, bolt another fastener system.
I get it, it's so you don't have to have two of the same size wrench but my ass doesn't work that way. I use a ratchet and a wrench. Or an impact and a wrench. I can handle both the nut and bolt being the same size. I'm an adult.
The reason they do that is because they don't pay their techs enough to have doubles of tools. This way, they always have the right tool. What can piss you off is when the bolt is one size and the nut is smaller and then the next bolt has a larger size nut.
More research says that air purge is related to the fuel for the seventh injector and Regen, not the def system.
I'm willing to bet it's from when I changed my fuel filters. Had a bit of a time getting it primed again to start, and I bet it didn't like that. Hopefully it's just a fluke code.
Here's that supposed purge valve thing that I said I couldn't get to but turns out I could.
From underneath it was easy. YouTube showed accessing it from up top, and there was no way.
I'm not sure if this alone will fix it or if it's the thing this thing goes into that's also faulty. I'll find out through trial and error and throw it in my memory bank for the future.
Okay so it turns out the purge VALVE is the entire box that thing screws into.
But the cause of the fault could be anything from that to the box itself, air supply, or the 7th injector.
Service data just says to "inspect" these things so apparently there's no test for it.
I'm just going to pull them apart, look at them, attempt to clean and/or replace on an incrementally costly basis. That little plug thing first then the 7th injector then the box.
The air supply is regulated by a valve that I replaced a little while ago because it was leaking so I doubt that's the culprit.
Cleaned that thing, reinstalled. Replaced air dryer filter. Drove around block. Parked, rescanned. Code inactive. Cleared codes. Rescanned. No codes. Key on, start, off, on, start and light still out and warning about system fault not shown.
So hopefully...*crosses fingers*
Filter overdue and maybe a little moisture getting to it?
I'm probably going to buy that box and replace it. I think it has downstream fallout damage from the old compressor. Or just age/quarry related crust.
There's not a lot to that system. The box has electrical plugs, air, and fuel lines. One is supply and the other goes to the 7th injector and that's it.
It's a $90 part online and a $600 part from the dealer. I think I'm going to just pony up the dealer price instead of repeating that nonsense with the def doser. They may look the same but there's probably a quality difference that'll rear its head later.
With nothing to lose, I shoved a little steam up through what I assume is the exhaust port of that high dollar box. I believe that's the valve that's sticking or stuck shut. I still don't know if it's always stuck closed or intermittently sticking closed. The only real test for it is to force a regen and see if it succeeds. I'd have to find an open area due to the high heat the exhaust generates to do that.
Welp. I broke the bolt holding the cover on. But I found out why steaming it did nothing. It's just solenoids. There's no "valve" like I was thinking as in a spring mechanism with a rubber diaphragm and whatnot.
So when the code says "valve stuck closed" it must mean clogged. My brain was thinking more along the lines of a broken or weak spring or gunk holding the diaphragm physically shut.
The little hole in the bottom that I was shooting water into is just an air hole for heat dissipation.
I'm learning.
I also decided, since it's solenoids, to take the downtime and wait for a cheapo off ebay.
Maybe it'll bite me but 80 bucks no core vs 600 plus core is a gamble I'm willing to take.
I'm probably stupid but in my mind solenoids are solenoids.
Have you tried removing the solenoids and cleaning up all the contacts and connection posts? I'm not sure what they are made of internally, but if you're going to take the down time, what do you have to lose by looking? ASSuming they are easy to remove and replace. Then it's free, aside of your labor. Free is best!
I agree free is best. I was looking at it upside down. Imagine being on a creeper doing an oil change.
Unfortunately I didn't see anything that I could really do or even how they're mounted. They definitely aren't bolted in like a transmission solenoid.
I don't really want to take the unit out of the truck in case the fuel lines piss diesel everywhere. I'd rather have the new unit ready to hook up and minimize the loss. I'm sort of picturing it like the def doser where the coolant just kept coming until you hooked everything up again.
I do believe I'll dissect it once it's off to see what's what though.
Is there like a factory service manual to the system that you can read up on it first? I'm just guessing at this stuff, I've never been into it.
