Oh no work today? No problem. that will give me more time to drink beer and or look for a another job.
Because I'm on a set salary, I beg not to work. Running during the day to local and smaller airports, in the summer it got real slow and I would work maybe 3-4 days a week. Working at night for the Military, it's almost a load every night. But one load at night (7 1/2 hours) sure beats 2-3 loads during the day at 10-12 hours.
I ended up getting groceries, mowing, and clearing some overgrowth that I had neglected.
Not a big day really but I find myself doing less on my days off than on my work days anymore. I think it's a wind up and momentum thing.
Some days I can be on my feet all day. About a month ago I worked in my shop for 26 hours straight.
Other days I don't do a damn thing but pull weeds.
I can't walk past a weed without pulling it out by its roots. I think it's a mental illness. 😬
No it's not. I hate weeds. I work hard to keep my yard weed free. Not so sure with a yard as large as yours if I would be.
Most asylums have more than one patient. You're both mental.
Saw probably a dozen or more Cup Series haulers headed back to NC last night. They don't f around at the track apparently. Around midnight they were already half way into VA.
Oh and after almost 60 hours parked the truck was down to 48psi in both air tanks with all the air bags still up. Didn't think to check the transmission tank to see if that was empty or not. If it still had air, it would have ruled out the air leaking out of the transmission. Maybe next time.
Either way, I'm gonna call it good considering it was 55psi after 10 hours before.
It's probably some random fitting somewhere that I'll stumble across accidentally some day. I doubt I'd find it even if I tried.
Just 69 more days. I refused the new truck. Give it to the new driver and let him start out fresh.
My Titanic has just turned 7 last week. I've kept up everything since I picked it up new, so it'll be a good truck to use as a spare or a trade. The worst part about air leaks is the load it puts on the compressor and air dryer.
7 years? Mine is now 9. 10 if you count the build date rather than the MY.
I had to replace the compressor late last year I think it was. I think the old Ford is on the original based on how much it clatters and having 386k miles.
Yeah, picked it July 17, 2016, as a new '17 model year. It had 1200 miles on it. That was from Denton TX., to Greensboro, N.C. Now it's at 395,000. Still strong, no smoke, no oil usage.
I just ran the numbers and I get 56,400/yr. It sat for the better part of 7 months after it was wrecked. Couldn't get a hood and just about everything forward of the firewall was replaced except the engine. Some dumb bitch turned right in front of me when the truck wasn't even a year old. I, T-boned her F-150 at 45mph. I thought that she was dead. The airbag curtains saved her dumb ass.
I'm at 556k now. Bought it at 426.
The clutch control module and associated fittings/tubing, caster wedge, and 5th wheel bushings were the biggest holy shit moments with this truck basically making it more livable than it's ever been. So my intention is to run it until it craps out or the safety lady pisses me off and makes me leave again.
The clutch has about 350k of life left if the wear is linear and it doesn't burn a drop of oil. It only seeps oil in two locations. One of which is a design flaw and not worth pursuing and the other being either my oil pan or the rear main. I haven't cleaned it off to tell for certain.
Either way, both are ounces of loss, maybe a quart, between oil changes so basically nothing on a system with 10 gallons. Not even enough to add or see on the dipstick.
I don't want to jinx myself but I believe I'm in a good place with it.
My hardest pull is the Dames Point bridge in Jacksonville over the St. John's River, on the east side of the I-295 bypass. Start at the bottom at 75 and crest it at 50. Damned limpdick Cummins. My Cat used to walk over that and never drop a gear. Same HP, torque and rears.
Trans and rears run between 170F & 185F, depending on the ambient temps. But the engine oil is at 225F all the time.
My trans used to get to 185 but I haven't seen it cross 180 since the module replacement.
I don't have rear end gauges, unfortunately.
My engine oil is typically 220-240. Mack is aggressive about moisture removal.
