Those 9-C1 Caprices will go 500,000 miles before needing an overhaul. Like the 4.6 in the Crown Vic. Both awesome cars if you could stand the looks of them. The Haitian cab drivers down in Ft. Lauderdale would beat the hell out of those CV's and they would keep on keepin' on. Park it under a shade tree, roll in a set of bearings and rings and get another 400k out of them.
Still fugly in bathtub form tho.
back in my wrench turning days, i had a customer that would buy used town cop cars, usually that dept had Chryslers.
all i had to do with nearly any of them was change out the timing chain, and gears, and spark plugs.
the cars had high miles, but didn't burn any oil.
then about 3 years later, he'd buy a replacement cop car, same repairs were done then too.
giving his son his last cop car.....things ran and ran.
I was just thinking. If I'm only dropping the trans to access the bell housing, I don't have to actually remove it from under the truck. Pull the driveshaft, lower it, back it up. Reverse process.
So I might get one of those jacks after all. It would be a good time to take the driveshaft to be checked/balanced as well.
I've been absent from your thread for a while.
Are you talking about one of the ten wheel trucks or one with 4 wheels?
then about 3 years later, ne'd buy a replacement cop car, same repairs were done then too.
Slant 6s? I had one in a van. Couldn't kill it even if you wanted to.
As much debris and oil as I cleaned out of the ports when replacing that module, I'm suspecting it was another casualty from when the compressor gave out.
Expensive little sucker at nearly $600 but since I could DIY it after a run yesterday, it's a whole lot cheaper than paying a shop a grand to tell me 3 days later it MIGHT be the module but they have the entire trans out already and it could be this that or another.
Noticed this damaged o-ring on the old control module. I bet it happened when they bolted it to the reman tranny. Probably came relatively bare and they reused parts. Would have been an additional air leak, probably. And might explain why even when I thought it was working fine it would sometimes scratch like a newbie.
It was flawless today. Shifts were more crisp and in time with the shoosh of the air puff. Not a single scratch or miss, and more willing to downshift for a hill or slowdown. And that was in economy mode.
Here I was thinking it was great all this time when it was actually not up to snuff. Near the end there it started acting like a Paccar or early DT12. Lag like crazy and the clutch jumping out during slow maneuvers.
Air goes from the shift cover to a port on top of the module then comes out that gold mesh thing and into the bell housing where another air line is attached going to the clutch actuator.
The worst thing about the early Slant 6's (170ci) was the damned oil filter was upside down. When you cracked the loose, near a quart of nasty oil went all over everything on the way to the drain pan. When they became a 225ci, the inverted the filter to almost normal. But about all you ever had to do to them was replace the spark plug steel sleeve O-ring. Pull the plug and the sleeve was loose. Just put a set of O-rings on at every plug change. Like valve guide seals on a small block Chevy, or the plastic coated timing chain cam sprocket on a GM product, it was just routine maintenance.
I lost a perfectly good 5.4 to my cheapness. I bought a variety pack of Amazon hose clamps for the oil cooler and they weren't up to the task. Lost all the oil driving home one day and that was that. For the Mack I've stuck to the Ideals that it had from the factory. They're still made here in Pennsylvania and you can crank the shit out of them and they won't cam out.
One thing the modern cars are getting right, IMHO, is the cartridge filter somewhere on top of the engine. It makes it stupid easy to change without making a colossal mess.
With my mom's Buick I can put the plastic bag I'm going to dispose of the filter in right next to it and get almost no drip on any components.
If only they could mount the oil pan to the roof for easier draining.... šŸ˜‚
Super excited to report my check engine light went out. šŸ‘šŸ˜
This sounds cheesy but service data said if you fixed the issue the light/code would go away when you pushed the brake button in, put it in gear, and started driving. Made it sound like it should have cleared immediately on my test drive.
That didn't happen yesterday so I was thinking maybe I didn't really fix it. I got to the rail and was trolling inside when it went out. So of course I was elated and as soon as I got stopped (parked under my load) I told y'all.
I think my van would have been a 225. I'm no expert. I think it was a 1990. My grandma gave me the van aka skin wagon (as dubbed by my dad) but I didn't know anything about it. I was just a dumb horny kid.
Not much has changed really except the van is gone and I'm no longer a kid.
In a police car? Not big enough.
The 225, though nearly indestructible, ain't got shit for power.
I doubt they'd even put a 170 in a van. But you never know. The auto industry has done other bone-headed things, like putting a 4 cylinder in a mustang, or when they discontinue their most popular models.
The dumbest thing Ford ever did was discontinue the 300-6 engine.
I don't really remember what the van had in it. I just remember doing literally zero maintenance. Not even an oil change. And it still survived me.
The kid me and the adult me are polar opposites.
no, all cop cars had V-8's....
i cannot recall whether they were 383's or 440's.
but yeah, the slant 6 was the work horse and well sought after from the bone yards, from recent wrecks
383 sounds familiar. It was a D50 with the Prospector conversion package.
Girls loved it. Their dads didn't.
