Something I've wanted to toy with since I started with the grow beds and fish tanks is using 12v bilge pumps for propulsion.
It seems that you could fashion thrusters from the bilge pumps if you position them in the front for intake and plumb the discharge to the rear.
Pond pumps are rated at the point of discharge while bilge pumps are rated at 3 feet of lift...
HUGE DIFFERENCE!!
You can buy an 1100 gph bilge pump for under $20
YIPPEE KI YAY!!!
:pickle:
:crash:
Gotta hook up some kinda scale to measure lbs of thrust.
Jet propulsion isn't very efficient at all.
Not in aircraft and not in the water.
The most efficient jet engines are actually turbofans. The jet turbine makes thrust in the center but the shaft turns a big blower fan that moves high volume, lower pressure air around it.
And actual jet engine isn't that big around, it's the fan part that makes them so big.
Propeller aircraft are the most efficient, looked at as energy to thrust ratio.
For some reason you lose efficiency when you have super high velocity fluid moving past static fluid right out the rear of the thruster. That's what the turbofans solve, by surrounding the high velocity jet blast with slower moving air.
:dunno:
But I'm assuming that even with water, the same principles are at work.
Only because if water jets were even close to as practical as a propeller, they'd be more common on jon boats. A jon boat is flat bottomed specifically for shallow water.
A water jet is ideal for shallow water propulsion though. Look at a jet ski on a trailer. The water nozzle is no lower than the bottom of the hull. It's not sticking down below, exposed to damage from rocks and beaching.
Another thing about props that make them suck in shallow water is what I incorrectly call cavitation.
The cavitation you referred to in your Detroit engine, I would have called "pitting" because the maritime use of the word is what I'm used to.
An introduction to propeller cavitation
An outboard motor can get cavitation at any depth but a trolling motor isn't powerful enough. That's why I'm technically wrong when I call it that.
But what happens to my trolling motor if I have it set for minimum depth is it pulls air down from the surface, makes little whirlpools & lots of awkward sounding noises you'd most likely associate with a public bathroom at a Taco Bell. o_O
I don't know what that effect is called, but I think it's caused by the low pressure on the front side of the prop, combined with turbulence. I call it cavitation even though I know it's incorrect, just similar.
@Hammer166? What's the science word for that?
LMAO, he's going to start charging for the use of his encyclopedia. :rolleyes:
Anyway, in order to run my trolling motor on top speed without it making those awful noises :eek: I have to set it so the top of the prop is at least 6" or so below the surface.
So with an 8" prop (I think) and the skeg sticking even deeper, I need the water to be over a foot deep even though the raft has only ever needed 4" even when loaded up.
And thank God for skegs. I'd have destroyed SO many trolling motor props in the shallow, rocky Des Plaines River without one.
I even had a skeg break off of one & when I got home I made a new one out of steel, bolting it to the aluminum I can't weld to, out of desperation because I didn't have the money for a new trolling motor. Amazingly it never broke. :confused:
We should have a national holiday just for the appreciation of boat motor skegs. :)
:dunno:
Had to break out some google fu for that one.
Ventilation is the term for air drawn from the surface by a shallow prop. Props designed for running ventilated tend to be designed with flat blade profiles, rather than airfoils.
Cavitation makes for interesting reading, that rabbit hole once led to reading about the bubblejet effect as it relates to underwater explosions. Basically a large, explosively induced cavitation bubble. Same forces, just scaled up, and able to shred steel.
Kinda interesting how giant ships can be sunk by air bubbles beneath the ship.
It's a Bermuda triangle theory but it's been demonstrated on a smaller scale.
They think some kind of geological activity on the sea floor releasing pockets of natural gas sunk some ships. The gas bubbles displace enough water that the water all around the ship is 50% gas bubbles, and the ship can no longer float so it sinks rapidly.
Yes, I'd read a very good article about that a while back. It talked about how the indigenous people of that area knew not to sail thru certain parts of there, long before the whole Bermuda triangle mythology arose.
I wonder how big of a compressed gas cylinder it would take for a submarine to use it to sink an enemy ship. Like if they could design the cylinder to split apart at the seams on command so it releases all it's gas all at once.
I bet the military has something like that already & we just don't know about it because they've used it for top secret stuff like sinking cargo ships bound for the USA that contain nuclear bombs planted by terrorists but can't use conventional channels to stop it because the terrorists are aboard the ship and will detonate it the second they realize they're busted or because if the Navy or Coast Guard raided the ship, the State Department would have to explain that we only knew about it because Agent Jack Bauer hacked into computers at the Saudi Arabian consulate's office in Brazil where the ship is registered.
:stare1:
....and, finally...
