ironpony
Professional Pot-Stirrer
Enslaved pandas pulling slow freight... Panda Express.Duh, there's no Pandas in Illinois
Maybe that's from the Bamboo FamilyThere's still green shit under a super thin outer layer I can barely scrape off with my fingernail.
I've seen tons of that stuff when I lived in Indiana and maybe even as far back as Kentucky but I'll be damned if I know what it's called either. Never really thought much about it.I wish I knew what species of plant this is.
It was the stalk of a weed I cut down behind the old wood barn 2 years ago.
It was a green stalk, a broadleaf plant like burdock but it grew about 5-6 feet high. I cut it all out and it all went on the burn pile except for this 3 foot piece I kept out of curiosity. I don't remember what piqued my curiosity though.
It was green and flexible when I cut it. I cut it with hand pruners the size of a pair of wire cutters and it was super easy to cut.
Now it's super strong and super light.
I mean I don't think I can snap it in half with my bare hands if I tried. It's as rigid as whatever wood they use for broom handles.
And it's so light I could probably balance it on the end of a cigarette, holding it by the filter. I mean it weighs almost nothing. But it's so damn strong I can barely flex it holding it by the ends.
Too bad I cut everything down again this year and poisoned the ground. I'm going to have to go out in the fields on the 4 wheeler and see if I can find some more.
But I just noticed this:
The core is soft like styrofoam. It's basically like a wooden tube with foam inside.
I just cut a piece off and dug out the foamy stuff with a drill bit.
Whatever it is, it grows wild in Illinois.![]()
I'm going to start making airplanes out of it.Duck just discovered a replacement for aluminum.
Don't fergit th' duck tape*.I'm going to start making airplanes out of it.
Like when MacGyver built an ultralight out of bamboo and some tarps.![]()
Here's a good one.I was just watching that the other day flipping through his videos looking for the bit in that special about stupid people.
Here's a good one.
Almost prophetic.Fitting for this fuckery going on eh?
Just always "wondering"..This room in the barn, at some point was insulated. There's old rotted insulation in the walls, planking on the interior wall, and..
... the ability to lock yourself in.
Makes me wonder what for.
Apparently it predates Tyvek too. They used plywood as a vapor barrier. This is what's behind the old siding I just pulled off.
I thought Van Wyk was ancient history.I turned the barn into a candy cane.
That's just primer on the molding strips. They're all red now. But I was tempted to leave it that way.![]()
They still around ...I thought Van Wyk was ancient history.
When do you actually drive?
I meant ancient history for him. Not as a company.They still around ...
I still see Van Wyck rolling down I 80
I hear ya "Loud & Clear"...I meant ancient history for him. Not as a company.
You know how when you quit a place and you know you'll never work there again, after a while (14 employers later in your case) they are ancient history to you.
I never quit. I've been continuously employed by them since 2005. I simply switched to "part time" and all I do now is rescue their junk when it breaks down and they ditch it at a shop in the Chicago area. This is the 2nd time this month.I thought Van Wyk was ancient history.
Ah 10-4. Wasn't trying to bust on you or anything.I never quit. I've been continuously employed by them since 2005. I simply switched to "part time" and all I do now is rescue their junk when it breaks down and they ditch it at a shop in the Chicago area. This is the 2nd time this month.
I picked this one up in Mokena today at that KW dealer next to I-80. Picking up a load to Sioux City tomorrow, ditching the truck at the yard and hitching a ride back.
For the first time in ten years, I'll be leaving Sarah home alone for two days and I don't like that idea. No idea why I agreed to do this. If it wasn't for the fact I gotta hitch a ride back with some other driver, I'd bring her with.
so lemme guess it took all day to paint 5 white linesI turned the barn into a candy cane.
