Sarcastic remark goes here
No I was doing truckular activities most of the dayso lemme guess it took all day to paint 5 white lines
uh hughNo I was doing truckular activities most of the day
hey @krelithous ...he "could have said".....uh hugh
out behind the barn tohey @krelithous ...he "could have said".....
he was doing 'testicular activities" most of the day......
i think there's a few of us that thought he retiredhey @krelithous ...he "could have said".....
stop freaking cussin now i gotta go take a nap. there's that nasty 4 letter word workNo I was doing truckular activities most of the day
Semi retired from semi drivingi think there's a few of us that thought he retired
Probably means he wasn't wearin' no panties...hey @krelithous ...he "could have said".....
More than we need to knowout behind the barn to
You could always take her with and fly backI never quit. I've been continuously employed by them since 2005. I simply switched to "part time" and all I do now is rescue their junk when it breaks down and they ditch it at a shop in the Chicago area. This is the 2nd time this month.
I picked this one up in Mokena today at that KW dealer next to I-80. Picking up a load to Sioux City tomorrow, ditching the truck at the yard and hitching a ride back.
For the first time in ten years, I'll be leaving Sarah home alone for two days and I don't like that idea. No idea why I agreed to do this. If it wasn't for the fact I gotta hitch a ride back with some other driver, I'd bring her with.
Sure in the hell dont want that vision eitherProbably means he wasn't wearin' no panties...
you got a lot of open spaces between those planks..View attachment 71458
Gotta make some molding for the upper part of the wall.
Tomorrow.
I'm lazy now.
That's how the barn is built.you got a lot of open spaces between those planks..
why..??
but come winter, the animals get a huge draft up thier tails, with all those spaces. (as the cold/wind) can blow thru the molding strips.That's how the barn is built.
They put 12 inch wide planks up, spaced a half inch apart on purpose to allow them to expand in summer humidity.
Then they put skinny molding strips over the gaps, nailed ONLY to the same framing stuff the planks are nailed to. The nails go through the gaps between the planks, I mean.
(In this picture, there's only primer on the molding strips, but they're all red now.)
The gaps in the siding on the lower wall are wider because I had to use planks that were only 11-1/4" wide but I wanted to keep them inline with the planks above.
The upper part of the wall has all its molding strips missing because they rotted and fell off. I'm going to cut 1x4s down to make replacements.
That’s what keeps them from getting pneumonia if you board it up tight with no ventilation and they get warm and then cold that’s when they get sick.but come winter, the animals get a huge draft up thier tails, with all those spaces. (as the cold/wind) can blow thru the molding strips.
how do you keep the animals from freezing to death? or getting pneumonia?
well educate me, if you would?That’s what keeps them from getting pneumonia if you board it up tight with no ventilation and they get warm and then cold that’s when they get sick.
I live in MN and I'm a dairy farmer. All of our heifers, dry cows, and steers live outside in 3 sided sheds. As long as they have a dry spot to lay down and some protection from the wind they are just fine.well educate me, if you would?
you got animals, in a barn. it's sub-zero temps, and the barn is like (in a way) wide open with those planks being spaced apart.
how do the animals stay warm, and not freeze to death? or get sick from the extreme weather?
You missed his point. Those trim strips close the gap. They aren't tied to the siding board, so the gap opens and closes behind the trim piece.well educate me, if you would?
