Matteson, IL. Same exit @Blood takes to get to the Ford plant.Not sure if your near a Home Depot but they have rack after rack of all different types of stuff that would probably work
if per some chance the hardware stores have nothing, for bushings, you may be able to try a rebuild shop that specializes in starters, generators, etc. or on the outside chance a transmission shop, for the pilot bushings for a manual transmission. usually, automotive bushings are of a tougher made quality, to last longer.A 3/8" air hose fits perfectly as bushings.
But I don't like how it's two pieces. Gonna hit up Ass Hardware tomorrow and see if they have something that'll work.
Meh... Or just weld the collar to the pulley.I'd take em in and have them welded up and them machined back to size.
Make some bushings out of uhmw material too.
It's for the front end loader pump.What all does it drive?
That and it doesn't look like there's any damper in that pulley, so it's catching the torque pulses from the crank, too.Weld it, the hydraulic surges will shatter the assembly.
Rubber won't last like uhmw will.
The wear you see is years of those surges
I need to take advantage of the fact I can get this thing reassembled without completely removing the doggone flippin' steer axle and front crossmember.He needs to call up Pittsburgh power and get himself a Mercury dampener
Are you sure it ain't from being metal on metal after the rubber bushings distintegrated?Weld it, the hydraulic surges will shatter the assembly.
What is uhmw? I mean is it common enough I can find one at Autozone or is it some weird thing that only process engineers know about?
Wouldn't that be too hard, and not absorb the torque shocks?Even polyurethane suspension bushings would be better than rubber
