I wish that thermostat would go lower. It's minimum setting is 45°. But it's zero out.
I turned it off for the night. But I'd have preferred to leave it on, set at like 25 or 30.
Lots of thermal mass in there.
Water is 3 or 4 times more effective as thermal mass then rock, concrete, etc.
If you could lay barrels along the top shelf of the pallet rack and fill them 3/4 full of water they would provide a pretty good heat sink.
My dream greenhouse would have a fish pond inside about 6 feet deep with 300 gallon IBC totes against the north wall.
A lot of climate control could be achieved with just circulation pumps triggered by temperature sensitive controls.
You should look into roofing the chicken coop with corrugated roofing installed horizontally...
then figure out a way to seal the shit-load of solar panels I've got to install on the south side.
You could probably generate enough juice to run the shop including A/C in the summer.
then figure out a way to seal the ****-load of solar panels I've got to install on the south side.
Was that stuff they use to repair cracked car windshields ever considered? I don't remember. I haven't even thought about those things since I started on the workshop.
What voltage does the thermostat work off of? Do you know? Or is it just a switch? Does it have a battery?
I doubt it.
It's like 20 bucks to repair a bulls eye so new panels would be MUCH cheaper.
I was thinking that just covering them with polycarbonate panels like I used on the greenhouse might be the most cost effective solution.
About $20 for a 2x8 sheet which is about $1.25 per square foot.
Protect them from precipitation and just let them degrade if they're going to.
Lets see. Micropr
Don't know. Never played with them before
Older, and currently the cheapest thermostats are a mechanical switch.
It's just a coil of copper or something. When it cools and contracts, the coil rotates, and weak magnets grab and hold the contact when the outer end gets close enough. As the temperature rises, the coil starts expanding and trying to rotate until it eventually breaks the magnetic connection.
When you adjust the temperature you simply rotate the thing the center of the coil is attached to.
I have no idea how the electronic ones work. It's all like algebra and geekspeak 'n' stuff.
If your thermostat will hold the program on a separate circuit or battery power the simplest solution that I know would be a simple farmers add-on outlet that powers on at just above freezing and powers off around 40 degrees.
Just run your thermostat 'always on' and plug the heater into the freeze protect outlet.
10 bucks at that farm store down the road...
K.I.S.S.
LINK
I think that's the old school way. It's called a bimetalic coil. Same as an old car used to set the choke in a carb. In my day the contact was made with a little like light bulb filled with mercury. When it tipped over it made contact with 2 wires.
I oughta just get this thing. I like the digital screen on the one I got though. I just got the cheapest one with a digital screen.
https://www.menards.com/main/heatin...ow-temperature-thermostat/p-1444433407212.htm
K.I.S.S.
LINK
Simultaneous posts...
Great minds think alike...
but then again...
so do morons!!
:p
:eek:
